Home > Puma (Tdci) > A Frame (V frame?)
InternationalDBA
United Kingdom 2008 Defender 110 Puma 2.4 SW Stornoway Grey
A Frame (V frame?)
Still with the chassis swap, I am moving the rear axle A frame from the old to the new chassis.
The 2 legs are attached to the chassis with thick bolts, which I have now removed.
The nuts have a strange clip attached to them which briefly seemed to serve to stop the nuts from turning but quickly got mangled.
Can I remove these clips and reuse the nuts without them?
Post #1011497 16th Oct 2023 10:43pm
A picture would be useful.
Post #1011503 16th Oct 2023 11:30pm
Ad-doublecab
United Kingdom 1995 Defender 110 300 Tdi DCPU Loire Blue
Yes I bought new bolt kit that came with nyloc’s
Post #1011504 16th Oct 2023 11:34pm
geobloke
Re: A Frame (V frame?)
Yeah those are a sort of locking mechanism like a nyloc but with metal. Think they are "all metal locking nuts"...
Like this - https://www.accu.co.uk/aerotight-nuts/4982...j5EALw_wcB
One use only like nylocs Thumbs Up
Post #1011515 17th Oct 2023 9:10am
NickMc
I know what you mean, yes you can use an ordinary nylon nut,it just makes them easier to assemble with the retaining clip. They do break very easy when you undo them and the threads have a bit of corrosion.
Post #1011570 17th Oct 2023 4:21pm
... The nuts have a strange clip attached to them which briefly seemed to serve to stop the nuts from turning but quickly got mangled...
I'd still be interested to see what you had, your description is intriguing! Could they have been Oddie stiff nuts?
Aerotite nuts are generally superior to Nylocs in almost every respect, but are harder to obtain and significantly more expensive, but your description doesn't make me think Aerotite.
Nylocs will do what you need.
Post #1011578 17th Oct 2023 6:25pm
NickMc
The nut is just a nyloc it has two fingers each side that stop it spinning when you tighten it, it’s an assembly line speed up. Fitted to the models without the “crows feet” brackets. I can take a picture tomorrow if you really want?
Post #1011585 17th Oct 2023 6:53pm
NickMc
The plates in question, I can’t find the part number for them though sorry.
Post #1012655 25th Oct 2023 10:04pm
Interesting, thanks. Never seen one with those before, and I can think of no reason why they're necessary.
Post #1012663 25th Oct 2023 10:50pm
NickMc
They’re only on the ones with the brackets incorporated into the chassis, as far as I know they’re to speed up production as there’s no need for anyone to hold them or mess about with spanners.
Post #1012665 25th Oct 2023 11:06pm
That makes sense. Every day a schoolday.... Thumbs Up
Post #1012715 26th Oct 2023 2:12pm
NickMc
Post #1012928 28th Oct 2023 12:40am
Thumbs Up
Post #1012936 28th Oct 2023 7:35am
