![]() | Home > Maintenance & Modifications > Best performance intercooler for 2.4 tdci |
NoLimits Member Since: 29 Dec 2022 Location: Somerset Posts: 59 ![]() ![]() ![]() |
I don't think there is much in it, I got mine remapped by BAS so I bought their intercooler at the same time, it's big and seems to work ok.
I'd choose who you want to buy the remap from and then buy their intercooler |
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 377 ![]() ![]() ![]() |
If possible, I'd look at getting one with Cast end tanks as these should be less prone to cracking around welds on the end tanks.
They're all a significant improvement over the standard item and for 99% of us, I'd say they're all pretty much interchangeable. I've only got experience of the BAS and Airtec ones(both have cast end tanks) but in reality I doubt you'd be able to tell which intercooler (from any of the uprated ones from the main suppliers) was fitted from the drivers seat. |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3707 ![]() ![]() ![]() |
BAS. Quality and customer service are superb.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Think the BAS ones don’t seem to split on the weld like some others.
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2455 ![]() ![]() |
I cant remember hearing of any issues from the following
BAS IRB Developments (sometimes hard to get hold of but knows his onions) Alive tuning 2011 Santorini Black USW XS. 2015 Discovery 4.5 Black pack Firenze red XS |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2324 ![]() ![]() ![]() |
My standard one popped.
Alisport one split (they did repair it free of charge) I now have a BAS one which is really nice quality > 110 XS Double Cab |
NorthernDefender90 Member Since: 19 Aug 2021 Location: Leeds Posts: 13 ![]() ![]() ![]() |
Thanks everyone, I'll talk to BAS to see if they have any in stock.
If not then the AIRTEC seems to be the next best with cast ends. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2270 ![]() ![]() |
On my 2.2 with aircon I found the BAS IC to be a very good fit, all you have to do, as with many other larger IC’s, is trim a redundant piece of plastic bracket off the main coolant radiator. BAS provides full instructions with diagrams.
I would also recommend fitting new BAS silicon hoses if you don’t have them already. |
