![]() | Home > Puma (Tdci) > Shocks |
fishrider Member Since: 01 Dec 2010 Location: Cornwall Posts: 79 ![]() ![]() ![]() |
I've installed OME shocks front and back but am running on the origional springs. Mine has seven seats. The most comfortable it's been is when I've been fully loaded . I've lowered the tyre pressure's and added some weight in the back over the axels which makes a huge difference when driving unladen.
What rating would the standard springs be in terms of A B C . A being light B being medium and C heavy duty springs. I've looked at the iron man springs and considering them. I don't need the landy to tow 3 tones or carry heavy equipment in so thinking of going to the lightest but obviously don't want to throw money away. Ps I'm quite happy as it is . Just tyres of everyone complaining about the bouncy ride . 110 HT TD5 - 110 XS SW Puma |
Defender 75
I've not heard of SE spec . Here it's County and XS which run on the standard spring. Heavy duty springs are an extra option you have to specify. 110 HT TD5 - 110 XS SW Puma |
Yup - complete rubbish. I had Terrafirma on the 90 and binned them after they started leaking after a short while. Ride was rubbish too. Changed back to standard HD springs and gas shocks. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
JSG , did you specify HD springs on your truck or do the SW come with as standard ? 110 HT TD5 - 110 XS SW Puma
To be honest, I don't know. When I bought it it had just had the Terrafirma kit fitted. As it was a Tombraider with extra weight as standard I went for HD to give a slightly firmer ride. John
Ah, no worries . I want to set mine up as a family wagon for the bumpy Cornish lanes here. I'd swap over to tougher springs again when going on trips. There's not a lot of info out there. I may just blow some wedge on some super light weight springs and report back here 110 HT TD5 - 110 XS SW Puma
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Which Terrafirma shocks did you have? |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 ![]() ![]() |
SE is basically the same as XS.
According to what I posted on color codes it came standard with HD at least in the front |
big bore expedition. not fit for purpose. I sent them back after photographing the problem, they gave me a refund on the rears, not the fronts, then did not communicate with me at all. I couldnt be bothered to chase them so resolved never to deal with them again. Plus it took 3 weeks from their arrival for them to even contact me. |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
when i researched my solution i was informed by LR that the 90 XS came with rear HD springs when ordered with a tow bar, which mine has. BM52 |
Interesting..I too ordered mine with a tow bar. Would be surprised if they put HD springs on it . The tow bar was fitted at the dealership when they recieved the car.
Without looking up colour codes anyone know what they are for HD spings on a 2011 build ? 110 HT TD5 - 110 XS SW Puma |
Standard
Blue/red drivers side Yellow/white passenger side HD Green/yellow/red drivers side Green/yellow /white passenger side Bob |
what about in the back? |
