Home > Technical > Performance?? 1994 TDI300 |
Cubflyer Member Since: 25 Sep 2021 Location: Suffolk Posts: 278 |
Hi folk
I really know nothing about this subject so hope you'll bear with me. As far as I'm aware my 94 Defender 90 has never had it's Injector's or Glow-plugs changed. If I change them ... should/would I notice a difference in perforance? OR ... "If they work - leave them alone?" Many thanks John PS: If they should be changed ... what make are recommended? 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
14th Oct 2023 6:19pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17539 |
Mileage?
14th Oct 2023 9:41pm |
Morning BW the milage is 155K 2010 Defender 90 300Tdi CW (White/1994)
15th Oct 2023 6:35am |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 821 |
My 94 300tdi runs like clockwork and regularly hits 85-90mph. 175k on the clock and totally standard!
As far as I can tell the biggest thing (other than everything being well maintained) is to make sure timing is optimised during timing belt changes. I find the static setting is just the start and actually driving the vehicle then nudging the timing +/- 1 degree in either direction to find the sweet spot during test drives gives the best result. I would be a rich man if I had a pound for every time someone asks me how my Defender has been 'chipped/tweaked'..... I could also make a similar amount of money from the number of people who swear I am running locking diffs Recently at Dalton off-road site in the Lakes I had a bloke who just wouldn't accept it. Conversation was something like this.... "Ok, so you have open diffs, but they are locked really aren't they!" |
15th Oct 2023 8:01am |
Thanks for your comments OS - appreciated as always
I love my 90 but sometimes feel it's lacking "something" but can't say what! ... ATB John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
15th Oct 2023 8:11am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
I may be way off track - but is it worth giving the fuel system an appropriate treatment - some injector cleaner?
15th Oct 2023 8:22am |
Hi Screbble - An interesting thought and one I'd never considered! - thank you!
I'm always skeptical of these additives ... can anyone offer their experiences having used them ... Thanks John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
15th Oct 2023 9:49am |
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1627 |
Hi, not a Defender but I ran a 200tdi in my 1966 series 2 and every couple of months I would pour in a diesel injector cleaner, in my opinion it worked as I kept that for 6 or 7 years with that engine and it pulled like a train albeit lighter than a defender I believe this additive definitely helped, the engine had done from memory 175k when we removed it from my mates Discovery and I averaged around 9/10 k miles a year commuting, Camping and visiting my mum in Axminster regularly cheers Paul
16th Oct 2023 11:05am |
Hi Paul - Thanks very much for taking the time to reply.
Certainly thinking about doing it after reading a few reports ... it would be good to know how many others are doing it too. All the best John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
16th Oct 2023 11:08am |
MercianRover Member Since: 07 Apr 2022 Location: Culworth Posts: 143 |
Garage I used recommended it - they have an diesel repair shop so I presume the advice was based on seeing vehicles where it was used and where it was not and practical observation of the injection parts on each.
16th Oct 2023 11:30am |
Thanks MR ... Your comment is welcomed, now looking at various brands.
Any one care to share what they use/have used. MTIA John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
16th Oct 2023 6:40pm |
Hi John, I’ve used STP and Wynns they both advertise to do the same job and I can’t say I noticed any difference between the two ie good results from both cheers Paul
16th Oct 2023 6:55pm |
Paul ... thanks very much for taking the time to read my thread and reply.
16th Oct 2023 7:09pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1654 |
Turners recommend new injectors over 100/120K
16th Oct 2023 7:32pm |
