![]() | Home > Puma (Tdci) > P2562-34 Code !!! |
thenorthdefender Member Since: 17 Dec 2022 Location: trabzon Posts: 7 ![]() ![]() ![]() |
p2562-34 getting an error
The motor, which started moving when the ignition was turned on, became rigidly stuck at the end of the actuator's travel. All cables checked 'actuator replaced with a new one 'no grounding 'egr canceled with software Has anyone encountered this error code? [/img][/url] |
I checked them all carefully. it looks good
shaun6 Member Since: 06 Mar 2013 Location: Houghton Regis, beds Posts: 46 ![]() ![]() ![]() |
Code P2562 means that Turbocharger Boost Control Position Sensor 'A' Circuit has been detected.
Yes . the problem still continues
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17609 ![]() ![]() ![]() |
If you are 100% certain the harness is OK and you've changed the actuator for a known good one (tested on another vehicle I hope) then all that is left is the ECM I'm afraid.
For some reason (usually a broken wire or grounded wire) the ECM is not detecting the actuator position from the stepper motor in the actuator and is driving it to its end stop whilst trying to position it. I'd still be suspicious of the harness and before buying a new ECM would be checking impedances and ground impedances of the actuator leads. I don't know how thorough your "looks good" means, of course, you may have done this already. |
I hope it's not the ECM
![]() Actuator replaced with new one, still stuck |
