Home > Maintenance & Modifications > Double glazed sunroof
wrcarter
Ireland 1989 Defender 110 200 Tdi CSW Portofino Red
Hi all,
My sunroof has started to leak. It the older pull down handle type The previous owner used some black silicone to seal it shut. I was thinking of trying to seal it again but that won’t stop the condensation in winter. I started to consider replacing the roof with a non sunroof one but then I came across this
https://vehicleglazingspecialists.com/inde...mp;path=86
Anyone fitted one or came across something similar? Do they actually stop condensation?
Thanks 1989 Land Rover 110 CSW
Post #904409 22nd May 2021 9:37am
Sulisuli
You won’t find a better glazing company to deal with Thumbs Up I’m sure if they sell it that it will be first class.
I have one of their glazing products and it’s first class. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #904475 22nd May 2021 7:33pm
Tegner
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
I'll second that top guys - fitted my panoramic glass windows
Post #904514 23rd May 2021 7:24am
wrcarter
Cheers lads. Seems like the best option so far. 1989 Land Rover 110 CSW
Post #904515 23rd May 2021 7:29am
Smcknighty
United Kingdom 1995 Defender 110 300 Tdi CSW Arles Blue
Did you do this? Did it fit?
Post #1010857 11th Oct 2023 10:44am
geobloke
Re: Double glazed sunroof
Pointless post by me...
Post #1010863 11th Oct 2023 11:17am
Smcknighty
Smile the answer to this may prove the are all sunroofs the same size or not. Saying that I ordered a sheet of aluminium anyway. Now just need to figure out where to get a small quantity of alpine white
Post #1010872 11th Oct 2023 1:03pm
TexasRover
In my experience sunroofs leak mainly because the various seals or drains age and go hard.
The Defender sunroof is a rather simple affair to remove and reseal and the seals are readily available. Surely this is simpler then covering it with a sheet of aluminium ?
Post #1010877 11th Oct 2023 1:34pm
geobloke
I have to agree with TR here. I have found that it is critical to clean and grease the main sunroof seal annually. I use a silicone grease on it and the door seals as it happens.
What is also critical with the LR sunroof is making sure the front hinges slide properly inside the plastic housings. If they do not the roof doesn't seal properly at the front.
The whole glass have been designed to be removed for the fully open driving experience. Lovely on a summers day.
Post #1010878 11th Oct 2023 1:41pm
Smcknighty
Mine needed resealing between roof and sunroof, I’ve removed it and I’m
In the process of getting the seized screws that I had to drill out out of the sunroof. Meanwhile I’m thinking how it used to condensate and drip on me in the morning and wondering what the point is Smile
Post #1010887 11th Oct 2023 2:47pm
gilarion
daft question maybe, but what grease do you use? For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #1010895 11th Oct 2023 4:02pm
geobloke
Hi Gilarion, no problem. It is SIFST720 silicone grease by Carbusonic. co.uk
This stuff https://www.carbusonic.co.uk/-500g-pure-si...ber-latex-
Great for o-ring lubrication, or other hoses etc when fitting too.
Post #1010910 11th Oct 2023 6:58pm
Smcknighty
I asked a price for a roof from a breaker on eBay - £1300!!!! Seriously..
It’s raining and there’s a big gap in the roof so I got trigger happy and ordered this
https://www.masai4x4.com/defender/shooting...s-c2993006
I was getting no where getting the screws out of the old one and didn’t fancy spending ages drilling them out to end up getting condensation dripped on again
Post #1010956 12th Oct 2023 8:39am
TexasRover
IMG I did not know that! Just fitted a (used) LR sunroof in my DCPU (it's garaged). Absolutely loving it, but it was quite mucky and have not cleaned it properly. Reading GB comments here I played with the lock, then the hinges and WOW it comes right out !
Fantastic thanks very much!
Post #1011254 15th Oct 2023 7:58am
