Home > Td5 > Oil Pan Drain Hole Stripped and More Saga |
Jhollow Member Since: 27 Apr 2022 Location: Ontario Posts: 83 |
So I knew I had a problem when I was removing the oil drain plug. This was my first oil change since getting the 90 last year. It's a 2006. I had resistance all the way out. I cleaned up the hole and it looked OK but when I tried putting the plug back in it just kept turning. Withdrew the plug and it was completely stripped (the hole).
I did a search but couldn't find something specific to the oil drain plug hole. The drain plug hole is recessed so I'm not sure if I can just retap the hole to M18? Current plug is M16x1.5. Should I use a time sert instead? I don't know how much metal I have around the hole so not sure how to approach this. Do I need to remove the oil pan? If so is this a big job? I've removed oil pans from other vehicles but the 90 is new to me work wise. Appreciate any assistance and guidance on this. Thanks. 2006 90 originally registered in Italy Last edited by Jhollow on 15th Oct 2023 10:56am. Edited 1 time in total |
7th Oct 2023 3:59pm |
Thanks Nick. Can you tell me which drain plug repair kit you have? Just so I know what I'm looking for.
Is there anything special to know when removing the sump pan? When I've done other vehicles I just remove a whole lot of bolts, pull it off, check that the oil pickup is clean, use a new gasket with some permatex gasket sealer and bolt back into place. Is that pretty much the same with the defender? 2006 90 originally registered in Italy |
7th Oct 2023 5:20pm |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 164 |
Don’t need to take the sump off.
I tapped mine out last year an put a taper bush in that the new plug screws in and out of. Threads in Aluminium that you screw in and out of frequently are not a good idea… |
7th Oct 2023 5:26pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 |
Once repaired fit a Femco oil drain plug. That way you don’t have the trouble again.
https://www.femco.com/oil-drain-plug/ Fitted them years ago to mine. |
7th Oct 2023 5:35pm |
Thanks. What do you mean by a taper bush?
I did find some drain plug repair kits on Amazon that provide an M17 tap with plugs and washers. 2006 90 originally registered in Italy |
7th Oct 2023 5:36pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1661 |
Yeah just two dowels for the crank seal. Personally I’ve not needed to remove it to fix the plug issue. A bit of oil flush through it before you put the new stuff in and it’ll still be dribbling out while you do it.
It’d be Monday before I could tell you, I think it’s this https://www.sealey.co.uk/product/563720615...-set---m17 although I have a big set with different sizes. Last edited by NickMc on 7th Oct 2023 5:43pm. Edited 1 time in total |
7th Oct 2023 5:40pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
Absolutely the right thing to do once repaired 👍 |
7th Oct 2023 5:42pm |
Yeah that’s the type works perfectly well on the td5. |
7th Oct 2023 5:45pm |
So I looked and they do not have an M17x1.5 drain plug. Only M18x1.5. 2006 90 originally registered in Italy |
7th Oct 2023 5:55pm |
Just thought I would follow up on this. Received the drain plug repair kit, retapped the hole to M17x1.5 and installed a new drain plug and washer that were part of the kit. The plug end was small enough that it fit within the recess of the plug hole. Topped up the oil and fingers crossed no leaks. When I finished the tap I put the vacuum to the hole very briefly and then poured in a litre of oil to hopefully wash out any bits I might have missed.
Thanks for everyones quick replies and confirming I could do this myself. Stress level has dropped considerably. 2006 90 originally registered in Italy |
9th Oct 2023 3:43pm |
Glad to hear you got it sorted it sounds like a much worse than job than it actually is
9th Oct 2023 7:43pm |
Used to be a complete convert to these drain plugs, until it got caught on a rock and sheared off... It made quite the mess. If you use these easy drain plugs then please pack the original into the bottom of you cubby box just in case you are away from home and need it. Anyway... They are great for clean oil changes though. |
9th Oct 2023 8:06pm |
Great news Just in time for winter too. |
9th Oct 2023 8:07pm |
So after installing a new drain plug in I attempted to remove the oil filter. I didn't know there was a special tool for this so tried all sorts of things, including a chain strap which just ended up punching a hole in the side of the filter. So I brought it to a Land Rover specialist and he had the special tool and was able to remove the old filter and install a new one. Note to self to get special tool.
My problem now is that he over filled the engine by about a litre or so of oil. Is there a way of extracting a litre of oil without having to take the plug out the bottom? I would just like to avoid the mess but if that is the only way so be it. I thought I would ask the collective before proceeding. Thanks again. 2006 90 originally registered in Italy |
15th Oct 2023 11:02am |
