Home > General & Technical (L663) > Hose rubbing on air filter canister
lightning
After Land Rover Assist flagged this issue and advised repair "at the earliest opportunity" l tried to get my local dealer, Sytner, to sort it.
They didn't replace the canister, just fitted a new hose.
I had to eventually fit the part myself because the dealer couldn't look at it again for over two months. I thought l would try to get the £110 that the part cost, back from Land Rover but sadly not.
They stated that the modified part wasn't necessary so they wouldn't pay for it. lt was only £110 so no big deal, but l guess l expected more, having spent £55,000.
l did send photos before and after the new part was fitted, and the temporary repair done by LR Assist.
UPDATE
After raising a complaint and sending the photos again l eventually received a refund for the part.
Post #1010163 5th Oct 2023 2:12pm
lightning
Original with LR Assist cable tie.
Hose replacement by Land Rover, still rubbing and another cable tie needed.
Replacement part which l had to fit myself, parts dept said "no modified part exists" and l said "order it anyway" this is what arrived.
At least it's fixed
Post #1010166 5th Oct 2023 2:37pm
LR Nuts
why do Dealership staff just lie to customers ??? and think they can get away with it !!!
They think we are all stupid Mad
Post #1010175 5th Oct 2023 3:28pm
lightning
Parts dept guy said that if a part has been superseded or modified then it comes up on the system, but nothing was coming up.
l am more disappointed with Land Rover not offering any refund. After all l saved their service dept having to fit it, which would likely have cost Land Rover over £100 plus the part.
Does anyone know if this was an official recall or warranty replacement item and if so, is there a reference or technical bulletin for it?
Post #1010178 5th Oct 2023 3:47pm
Tim in Scotland
I don’t believe it was a recall or even a TSB. My February built D250 came with the modified filter box from the factory. The chaffed through hose would have been a warranty item on your car but I suspect JLR would prefer to just keep on replacing that hose than to do a proper job.
Might be worth asking on the JLR twitter/ X page why the box isn’t a replacement under warranty item. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #1010182 5th Oct 2023 4:12pm
J77
There is or was something about it on Topix. 24MY 90 D250 HSE, Tasman Blue
Post #1010200 5th Oct 2023 8:31pm
lightning
lf
someone could post it on here l'll send it to LR customer service
Post #1010202 5th Oct 2023 8:43pm
J77
I’m assuming this is it
Field Action - N785v2 - Engine Coolant Pipe and Elbow - Renew 24MY 90 D250 HSE, Tasman Blue
Post #1010208 5th Oct 2023 9:23pm
lightning
Could you possibly post a link or the document?
Post #1010342 6th Oct 2023 8:30pm
lightning
Can anyone copy and paste the document so l can see if l have a case?
Post #1010530 8th Oct 2023 5:18pm
J77
Sorry I don’t have the document, need a paid subscription. 24MY 90 D250 HSE, Tasman Blue
Post #1010538 8th Oct 2023 6:32pm
lightning
Would it only be the Land Rover dealer that would have that, or would my independent LR garage have the information?
Post #1010541 8th Oct 2023 7:03pm
Ap077
That’s the recall for a pipe from the turbo, to another pipe down the back of the bulkhead, and to replace a plastic Elbow, with a metal one.
I’ll try and find the SSM tomorrow
Post #1011275 15th Oct 2023 10:23am
mbso
Italy
Service fixed for my hose rubbed. No official racall
Hi guys,
this morning our Genoa Land Rover dealer, check the hose rubbed:
- they check for an official LR recall action, and they say there isn't.
- they verify the hose rubbed, a little scratched... but decide to change the hose and do something ( I don't know what Question ) with the air filter cover.
(I understood ...they ordered the hose)
The problem is not so urgent; I fixed for the first week of November.
I will inform you about the work done.
(I have just 8000 km with no issues Cool, MY23.5 D250 SE) ) DISCOVERY 4 2013
VOLVO XC90 2017
MY23.5 110 D250 SE in Santorini Black
Post #1011442 16th Oct 2023 3:20pm
Retroanaconda
What’s the replacement part number? My hose was replaced too but the new one is touching the canister as well, so just going to swap it out.
Post #1011462 16th Oct 2023 6:31pm
