Page 1355 of 1386 <123 ... 135413551356 ... 138413851386>
geobloke
Agree it will be a combination of all the newly fitted parts. But... I have only changed the diff and it is smooth as silk and as many have said there is a definitely reduction in drivetrain slack.
How did you find the steering with all the new bits?
Post #1009718 2nd Oct 2023 11:30am
excossack
Steering is better, but I do think I have some play which might not have as noticeable before due to the slop in the swivels. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1009724 2nd Oct 2023 11:47am
geobloke
Think ball joints and steering UJs to begin with. If you do change the track rod ends get the greasable ones or add your own grease nipples.
Post #1009727 2nd Oct 2023 11:53am
excossack
Steering column to steering box has been replaced. Ball joints are a good place to start. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1009728 2nd Oct 2023 11:56am
geobloke
It is amazing the difference replacing the three TREs makes to the steering "feel".
Post #1009732 2nd Oct 2023 12:15pm
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Finally got around to fitting the Optimil quick release boss to my Momo steering wheel. Also the locking cover. Should have done this years ago but I got an old school steering lock instead.
Really easy to fit, took 30mins. Really impressed. I guess I’ll be the guy in the pub holding a steering wheel from now on Rolling with laughter
Chris
Post #1010734 10th Oct 2023 12:39pm
excossack
Not strictly Defender but the night heater in my Defender had decided that it was going to need sometimes 3 or 4 starts to make it kick into life and produce warm air. Sometimes it would start and produce smoke and spin the fans other times not.
On looking at the wiring I spotted a crimp connector that looked the wires had started to pull out.
Cut, stripped, added some heat shrink and re-soldered the connectors and three out three times the heater has kicked in.
Hopefully this is all the issue was.. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1010747 10th Oct 2023 3:23pm
LR Nuts
mechanical electrical joins are good, but solder electrical joins are much much better. Thumbs Up Thumbs Up
Post #1010760 10th Oct 2023 4:42pm
geobloke
Winch Thumbs Up
Post #1010778 10th Oct 2023 7:49pm
excossack
Yesterday was a trip to Silverstone for a round of the HSCC event, managed 350miles to a tank or about 27mpg Smile which was nice.
Today, started trying to trace a whistle while on boost. Checked the hoses from the turbo to the intercooler and all good, made sure the jubilee clips are nice and tight.
Then moved to the inlet side. Noticed there appeared to be some oil seaping past the inlet manifold and the flange for the intercooler pipe join/faces.
Cleaned the faces up and degreased, and then applied some sealant.
While in the area I also cleaned the manifold temp/pressure sensor.
Not sure if the join was leaking enough to allow air out underboost but its worth cleaning and resealing.
Checked coolant/screen wash as well. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1011337 15th Oct 2023 8:46pm
excossack
Yesterday doing a few basic checks
Oil, waters etc I checked the wiper arms and noticed the passenger side wiper arm was a bit sloppy.
On closer inspection two things causes sloppiness
1. The splined adapter grub screw had backed off
2. The rivet that acts as a pivot point on the wiper arm had snapped the head off and caused the wiper arm to not sit correctly and this also explains the clunk on full sweep
Pics
Before
After a quick repair with a nut and bolt
Clunking now gone Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #1013044 29th Oct 2023 8:49am
AJC
Today I set about civilising my 110 for more family friendly use.
The 2 inch lift is coming off, fitting puma springs along with front and rear anti roll bars.
The 255/85s are coming off in lieu of some 265/75’s.
Factory tow bar going back on.
I’ve realised I’ve not been using it as much as I should as it’s easier to jump in the D2. I’ve not done a challenging lane or off road course now for close to 2 years so I don’t need the lift or tyres. I can still lane if I want too at standard ride height.
Old age kicking in
Post #1013128 29th Oct 2023 7:39pm
Screbble
Aren’t you supposed to grow old disgracefully? Rolling with laughter
Probably quite therapeutic returning to stock?
Post #1013131 29th Oct 2023 8:06pm
excossack
A quick airfilter and fuel filter swap and while under the bonnet, I noticed the turbo to intercooler hose had a layer of oil on it. The hose was cleaned when I removed them the other week.
The turbo return hose was clean.
Mmmm, more investigation needed. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1013221 30th Oct 2023 5:25pm
rustandoil
Zoom in and you might see my eight O'clock misery Big Cry
Post #1013322 31st Oct 2023 10:32am
