![]() | Home > Puma (Tdci) > Oil leak in sump area |
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 ![]() ![]() ![]() |
Sorry 2.4tdci
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2456 ![]() ![]() ![]() |
Yes it looks like the silicon gasket "failed" and the oil is not coming from the bellhousing. If you are able to remove the sump without deforming the mating face, you can re use it. Puma 110" SW
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2175 ![]() ![]() |
I would not reuse the sump pan, they are very thin metal and suffer corrosion.
My advice is to get a new one ( with notch to avoid damage by front prop) paint with chassis paint. Fit and then coat with chassis wax, I.e Bilt hamber dynax UB and it should last well. Ps there is a laser tool that helps getting the sump off. Laser 5026. |
Well its good news that it looks like its the sump gasket, new one is a good call, dont think they are too expensive.
Is this a common failure? I only ask as i appear to have positive crank pressure, undiagnosed, so am due to check injector seals, could this lead to such a failure? ie should i get that sorted before i change this? |
IMO too much blow-by will go through the crankshaft seals. I have not seen many oil sumps leaking. Puma 110" SW
Good News, ill get on and change this sump over
