![]() | Home > General & Technical (L663) > Software Version 4.0.0 |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 ![]() ![]() ![]() |
Apparently the maps in IDD is down to developers, so Google Maps may appear at some point as well. Doesn't give directions from CarPlay in the HUD though - which would probably be more useful.
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 507 ![]() |
Yeah, that would be very useful.
I found just having the directions directly in front of me was already a good improvement, and safer than over in the central display panel. |
ben2012 Member Since: 10 Oct 2011 Location: Uk Posts: 64 ![]() |
I keep getting the update on the car, I’ve selected both immediate upgrade and scheduled but it won’t actually update. Any suggestions?
All I know is that it needs a full close down, lock and alarm before it'll start the update..
I found a fix to my original problem - it seems you have to log in with a Profile, in order to save stations.
I still don't think the way mine behaves when logged out of a profile, is correct, but by logging into the profile and setting up favourites, it seems ot keep to the chosen source and cycles through DAB favourites correctly. |
Stimulant Member Since: 26 Apr 2023 Location: London Posts: 4 ![]() ![]() |
Im on 4.0.0 now but I still dont have the horizontal lines the were introduced on the previous version for the reversing camera. Anyone any idea why?
holtenc Member Since: 15 Aug 2023 Location: TX Posts: 28 ![]() ![]() |
Received the update today. Followed on-screen instructions and it failed to install twice. It never gave a reason for the failure. I connected a battery minder to the battery and waited until it indicated battery was fully charged. Initiated the install and waited a full hour before returning to the vehicle (on-screen instructions say it takes an estimated 35 minutes 3.3.3 -> 4.0 ). No idea if having a fully charged battery made any difference but it did complete the install that time. |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 109 ![]() ![]() |
Where/how do you connect your battery minder?
There are remote pos/neg terminals under the hood on the passenger side. The pos is in a small red plastic box. Neg is an exposed terminal about a foot away closer to the engine.
Ive been on 4.0.1 since 19th August but today it downloaded an 'update', however that is to go back to 4.0.0 has anyone else had this?
