Home > General & Technical (L663) > Software Version 4.0.0 |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 |
Apparently the maps in IDD is down to developers, so Google Maps may appear at some point as well. Doesn't give directions from CarPlay in the HUD though - which would probably be more useful.
2nd Aug 2023 10:03am |
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 489 |
Yeah, that would be very useful.
I found just having the directions directly in front of me was already a good improvement, and safer than over in the central display panel. |
2nd Aug 2023 10:18am |
ben2012 Member Since: 10 Oct 2011 Location: Uk Posts: 64 |
I keep getting the update on the car, I’ve selected both immediate upgrade and scheduled but it won’t actually update. Any suggestions?
14th Aug 2023 9:20pm |
All I know is that it needs a full close down, lock and alarm before it'll start the update..
15th Aug 2023 11:26am |
I found a fix to my original problem - it seems you have to log in with a Profile, in order to save stations.
I still don't think the way mine behaves when logged out of a profile, is correct, but by logging into the profile and setting up favourites, it seems ot keep to the chosen source and cycles through DAB favourites correctly. |
15th Aug 2023 11:28am |
Stimulant Member Since: 26 Apr 2023 Location: London Posts: 3 |
Im on 4.0.0 now but I still dont have the horizontal lines the were introduced on the previous version for the reversing camera. Anyone any idea why?
16th Aug 2023 6:04pm |
holtenc Member Since: 15 Aug 2023 Location: TX Posts: 28 |
Received the update today. Followed on-screen instructions and it failed to install twice. It never gave a reason for the failure. I connected a battery minder to the battery and waited until it indicated battery was fully charged. Initiated the install and waited a full hour before returning to the vehicle (on-screen instructions say it takes an estimated 35 minutes 3.3.3 -> 4.0 ). No idea if having a fully charged battery made any difference but it did complete the install that time. |
18th Aug 2023 8:28pm |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 107 |
Where/how do you connect your battery minder?
18th Aug 2023 9:32pm |
There are remote pos/neg terminals under the hood on the passenger side. The pos is in a small red plastic box. Neg is an exposed terminal about a foot away closer to the engine.
18th Aug 2023 9:50pm |
Ive been on 4.0.1 since 19th August but today it downloaded an 'update', however that is to go back to 4.0.0 has anyone else had this?
21st Sep 2023 5:10pm |
