Home > General & Technical (L663) > Can someone tell me what this is pls.... |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1418 |
Click image to enlarge If you mean this one, I'm not really sure, mine doesn't have a button there As well as the handbrake release there is a knob for dimming the instrument lights. It's hard to tell but is that a rocker switch? Does it have any extra lights fitted? According to the Iguide there is also a Fuel Filler Flap Lock on PHEV but you mentioned it's a D300 Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
19th Sep 2023 11:44pm |
Bows Member Since: 07 May 2012 Location: Wales Posts: 513 |
No idea sorry, but I would have thought that all the information you need would be in the handbook. 2006 TD5110 station wagon
1995 300Tdi 90 truck cab 1989 90 hard top with 200 tdi 1983 110 hard top 1983 110 Hi cap 1954 107 pick up |
20th Sep 2023 5:48am |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1140 |
That switch can be for the front fog lamps, if fitted as an after market by dealer or previous owner.
When front fogs are fitted by the factory, the control is on the steering wheel stalks. Click image to enlarge Take a look at this eBay set of photos .... last photo shows switch position https://www.ebay.co.uk/itm/265862422376 |
20th Sep 2023 7:46am |
milesg7 Member Since: 13 Sep 2023 Location: Cheltenham Posts: 67 |
Thank you all. He's going to look again later and will ask / send more pics!!
20th Sep 2023 9:29am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2825 |
Press the button and see what happens!
20th Sep 2023 9:20pm |
