![]() | Home > Technical > Ignition barrel |
Big Red the Yorkshire Defender Member Since: 25 Aug 2023 Location: Darlington Posts: 8 ![]() ![]() ![]() |
Hi, I am fitting the attached new ignition barrel, do I need to program the the key to the car in any way, and if so how? Thanks
What age Defender?
Yes a 110 Puma, thank you both!
I completed the work this week, it turned out there was some programming (ish) to accept the key using the key fob.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
The ignition switch/barrel is definitely not an item which requires programming, so you've had to have that done for some other reason.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2146 ![]() ![]() |
I bet that other reason was the fob needed a resync, ie. with doors shut press fob lock button four times in quick succession then unlock button once.
Which would have been nothing to do with the barrel being replaced. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4742 ![]() ![]() |
My 2008had an ignition barrel change and no programming was required. 1982 88" 2.25 diesel
