  • You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Technical > Ignition barrel
Big Red the Yorkshire Defender
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Rimini Red
Ignition barrel
Hi, I am fitting the attached new ignition barrel, do I need to program the the key to the car in any way, and if so how? Thanks
Post #1007939 17th Sep 2023 12:24pm
geobloke
What age Defender?
Post #1007942 17th Sep 2023 12:34pm
Ianh
Looking at prior posts Big Red has a Puma 110.
So no you do not need to reprogram the key if changing the ignition barrel.
Post #1007951 17th Sep 2023 2:53pm
Yes a 110 Puma, thank you both!
Post #1007971 17th Sep 2023 4:06pm
I completed the work this week, it turned out there was some programming (ish) to accept the key using the key fob.
Post #1008479 22nd Sep 2023 2:35pm
Martin
Site Admin
The ignition switch/barrel is definitely not an item which requires programming, so you've had to have that done for some other reason.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1008482 22nd Sep 2023 2:48pm
Ianh
I bet that other reason was the fob needed a resync, ie. with doors shut press fob lock button four times in quick succession then unlock button once.
Which would have been nothing to do with the barrel being replaced.
Post #1008485 22nd Sep 2023 3:17pm
spudfan
Ireland
My 2008had an ignition barrel change and no programming was required. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1008540 22nd Sep 2023 11:16pm
