Home > Maintenance & Modifications > coolant cap woes
bear100
coolant cap woes
a little while ago i noticed the distinctive hot coolant smell and looked under the bonnet after a 2 hour drive and found that the coolant tank cap was passing, even more evident when cool due to the satins on the tank, i have since changed the cap for an Iveco version which is recommended on here but still it happens? I've recently changed the tank for an Optimil aluminium one with sight gauge and flushed the system, added new antifreeze nut still after a 2 hour journey have the same issue
I always have my Ultrgauge on and the temperature from the CHT will hover around 83-96c
83 average motorway cruising 96 big uphill section.
haven't towed my caravan with the defender for a while but the temp would go to 110c up a big hill but never had any issues.
what would cause the cap to discharge? obviously pressure but what causes it? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1007322 12th Sep 2023 6:12am
geobloke
Check over the entire coolant system for loose hose clips, cracks, slits or evidence of leaks. Worst it could be is a cracked head or head gasket gone.
Here is a thread to read https://www.defender2.net/forum/post986512.html
Post #1007330 12th Sep 2023 7:46am
bear100
Would a leak cause the coolant cap to discharge?
It’s gives a hiss on occasions when hot.
Wasn’t expecting head gasket to be honest Shocked I will check it all over 2023 Defender L663 V8
Post #1007489 13th Sep 2023 2:07pm
