![]() | Home > Modifications & Maintenance (L663) > BREMBO 6-Pot Brake Upgrade |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2939 ![]() ![]() |
Thanks Marco, good info
![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Got these from the dealer today but does anyone know if a brake bleed and setup is straightforward on the L663?
![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 498 ![]() ![]() |
Usually not a problem so long as you keep the hoses clamped off and system full of fluid, just normal bleeding procedure Andy
Thanks Linds Andy
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 173 ![]() ![]() |
[quote="mcma1"]Got these from the dealer today but does anyone know if a brake bleed and setup is straightforward on the L663?
![]() Click image to enlarge[/quote hello, on the Defender it is a problem..... you must first of all put the braking system , abs in service , using the gap tool or the Land Rover wizard, otherwise you will not purge anything and only errors......on the bcm. secondly, an economic system would be recommended to put pressure on the system, without this the result is not guaranteed. I'll give you a summary of the procedure. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
The method Linds described sounds much easier
the job is certainly not simple, this "manual" procedure should (I'm not sure) set the service mode, and give the possibility to bleed the brakes.
to apply pressure I use this economical tool. I didn't understand one thing..... you already have six-piston brake calipers on your defender, are you replacing them just for the color? ![]() Click image to enlarge ![]() Click image to enlarge |
Yes they look really poor un painted. It is just easier and quicker to swap them out. I will perhaps have the current 6 pots powder coated and sell them when removed. Andy
ok,
![]() the six piston brake calipers contain a lot of oil, when you connect them, before bleeding, fill the oil tank, top it up, wait with the valves open without applying pressure and without the brake pedal until it starts to oil coming out of the valves. |
Steve34 Member Since: 17 Feb 2024 Location: Milan Posts: 3 ![]() ![]() |
Buongiorno Marco, io ho il defender 110 2024 200 cv con cerchi da 20 e pinze piccole, secondo te posso installare le pinze come le tue? Grazie
abyss Member Since: 30 Sep 2017 Location: Melbourne Posts: 33 ![]() ![]() |
My car is P400S came with 365mm front brake disc and Brembo 4 pot calipers. I’m looking to upgrade to Brembo 6 pots 380mm.
Apart from new 380mm discs and pads. Do I need new hubs and new shims? |
Mine is exactly like this. 365mm disc. |
Hi Steve, sorry for the delay in replying, I hadn't seen the message, on the 20" rim you can install the 6-piston Brembo calipers and 380 discs, as you can see from the back of a complicated job. Marco |
Hi, even for systems with 365 brake discs it is necessary to replace the wheel hubs, alternatively use caliper spacers of about 5 mm, a job that I personally do not recommend, given the workload on the brake caliper. Marco |
