Home > Maintenance & Modifications > Rear forward seat - modified for more reclining
Dinnu
Has anyone modified rear forward facing seats such that they can recline a bit more?
Reason for this question… I like to make more road trips with the Defender, a 90, but seems the car (an aging Golf) is still being voted for long road trips by the rest of the family Sad as they consider it as more comfortable and easier on the kids on the rear bench seat. The 90 is quite tight with luggage between the rear forward facing seats Crying or Very sad
I do like a 110, but parking size/ garage space required puts me off. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1005670 28th Aug 2023 8:45pm
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
Yes, I have done this to the 3rd row seats in my 110 Puma some years back.
Do not expect to gain a lot, however I have had no adverse effect, so no reason not to do it.
Unfortunately I have no pictures to share, but once the necessary trim and plastics are removed to reveal the mechanism it shall be relatively obvious as to what must be done. For each seat, it requires removing one round bush on one side and one steel washer on the other side. The steel washer is point welded to the seat frame, an angle grinder is your friend to take it out easily.
/Mat
Post #1005700 29th Aug 2023 9:31am
excossack
When I picked up my rear seats from a forum member, they also came with a kit to allow more reclining of the rear seats. I can take pics if you want Dinnu ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1005716 29th Aug 2023 10:57am
Dinnu
Thank you for the replies. I admit I have not done any investigation, but will do … the question popped into my mind as currently traveling with the car as SWMO makes all excuses not to use the Defender Big Cry
Excossak, are the Td5 seats with same mechanism? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1005827 29th Aug 2023 9:28pm
excossack
Not sure Dinnu. I will take some pics tomorrow and Whatsapp them over to you if OK ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #1005838 29th Aug 2023 10:08pm
Dinnu
Thank you for the pictures John. Top man Thumbs Up
Will see what I can sort. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1005899 30th Aug 2023 12:37pm
excossack
No probs.
I wonder if front seat reclining mechanism can be adapted to fit? 1999 Defender TD5 110
Regards
John M0VAZ
Post #1005903 30th Aug 2023 1:47pm
Dinnu
That could also be something as the front seat backs are able to go flat on the base if they do not hit the dash. But I hope I find something that only needs minor modification to the current seat frame. Need to find time to investigate Mat’s suggestion too 👍 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1005941 30th Aug 2023 6:01pm
