Home > Puma (Tdci) > Help with strange fault please. |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 521 |
According to the blurb in the manuals that's classic failure of the accelerator pedal position potentiometers..
No throttle response raised idle but try depressing the brake pedal.. It should reduce the revs.. You could check the connections at the unit.. I think there is a common earth.. If that was iffy it might cause the failure.. |
26th Aug 2023 9:23am |
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 260 |
Thanks Andy. I did think it might be that. Had a look at the wiring when it happened. Looks a bit ratty but all connected.
Next time it does it I’ll try the brakes thing. I did have a throttle issue years ago on a Puma and it threw the MIL light on. 2011 130 Utility Body 2005 110 Van |
26th Aug 2023 7:50pm |
