![]() | Home > Technical > Salisbury Rear Axle Hub with ABS |
olistr Member Since: 29 Dec 2022 Location: BW Posts: 66 ![]() ![]() |
After some additional research.
It seems that starting MY99, there is no differenciation between Rear Hun Axles for Salisbury and Rover types. So the correct part number would be FTC3188. Would be great if anybody could confirm. Thx |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 ![]() ![]() ![]() |
I am fairly sure that there are different parts/numbers for salisbury vs P38/Rover axles. See here - https://www.lrworkshop.com/diagrams/land-r...0456_52628
I can't remember if the bolt patterns are the same between the two stub axles, but they are quite different in profile. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
FTC3188 is the correct number for late salisbury axles with ABS sensor casting. I went through this pain myself last year when trying to replace my stub axles.
I even added the comment on LR workshop noting that FTC1740 was not the correct part for later ABS axles. Steve 02' 110 TD5 Double Cab Rebuild Thread |
Great Rallysteve,
thx all again for the feedback |
