Home > General & Technical (L663) > Side steps
Page 3 of 3 <123
dshark1
United States
@lightning
Question, just got my 110 , it came with factory side steps that I want to remove. Is it fair to say that, all it takes, is the removal of the two brackets from each side (4 bolts )?? Also is it ok to be under the vehicle with the air suspension at max height? Reason I ask is , read that the vehicle can lower without warning. Any input, much appreciated
Post #996555 17th Jun 2023 3:57am
J77
Personally I wouldn’t chance it, but leaving the doors open I think prevents it from dropping or at least it used to work on the Disco. 24MY 90 D250 HSE, Tasman Blue
Post #996590 17th Jun 2023 10:19am
lightning
lt depends on whether the person who fitted the side steps, installed the two small bolts in the side of each bracket.
To do this, requires the plastic sill and other parts to be removed. And to remove the brackets you'll have to pull all this off again.
Hopefully they will have done as l did, and just fitted the two large bolts, try removing the two bolts from the bottom of one of the brackets. lf the bracket comes away from the car, you're in luck.
Post #996595 17th Jun 2023 11:03am
dshark1
United States
@lightning
Thx for replying,
Yes I think I will test soon. Sure hope it’s that simple , I do not want to start ripping plastic off!
What is even the purpose for the smaller screws u speak of?
Post #996615 17th Jun 2023 2:26pm
dshark1
United States
Thx for replying,
Yes I think I will test soon. It came from factory with the steps, Sure hope it’s that simple , I do not want to start ripping plastic off!
Post #996616 17th Jun 2023 2:26pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Factory/ Dealer fitted steps will have all bolts fitted without doubt.
You would have to pull off your cills and some arch trims to get to bolts.
Mudflaps too if you have them.
I would live with the steps .. you may grow to like them
Clemmo Thumbs Up
See here
https://accessories-instructions.landrover...r/G2435685 Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #996630 17th Jun 2023 4:35pm
dshark1
United States
I just can’t understand the logic in all that. When all that would and should be needed to do, is unbolt the bolts that support the brackets? As illustrated in this picture by @lightning what roll do the mudflaps etc… have to do with them?
Post #996635 17th Jun 2023 5:14pm
Clemmo
Look at the Land Rover instructions??
You can’t unbolt the brackets without removing lots of trim.
Lightning did a self install and chose to leave bolts out
A good workaround.
Your car is not the same
You can remove steps. You cannot remove the brackets unless you take off cills , arches, flaps.
Clemmo Make today a little better than yesterday but not so good as tomorrow....
Post #996640 17th Jun 2023 6:28pm
mcma1
So I received my aftermarket steps for the 110. As with the LR kit you need to remove all the trims etc to fit the horizontal bolts into the brackets. I had a look at the Urban steps and instructions and they only use the 2 larger bolts up into the sills per bracket to save the trim removal exercise. So would you risk fitting these like Urban or remove everything? Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #1004747 19th Aug 2023 2:50pm
Clemmo
I fitted aftermarket steps.
I never removed any trim whatsoever.
I found the positions and simply cut squares out with a multi tool.
So simple. Very easy task
Fitted using vertical bolts only and rock solid.
I have no concerns at all
Clemmo👍 Make today a little better than yesterday but not so good as tomorrow....
Post #1004768 19th Aug 2023 6:51pm
Page 3 of 3 <123
