Home > Off Topic > Shed roof covering - EDPM or Felt
excossack
The shed build goes up bank holiday weekend - yay ! at last some might say.
Anyways. I was thinking instead of standard felt, I was thinking of EDPM instead.
Anyone gone down this route for a shed roof? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1004316 16th Aug 2023 8:56am
Ianh
I’m assuming it’s flat roof, ie a pent roof not an apex.
If flat and made of tightly butted and supported sheet material, I.e OSB supported at butt joints then EDPM will be massively superior to standard shed felt.
It will be more expensive as you will need the correct adhesives and edge profiles and likely end up with expensive adhesive left over .
But if done correctly will last 30- 50 years..
As for experience doing it, yes I did it for a neighbour, however at 30ft x12ft it was less of a shed, more of a timber framed outbuilding to be used as workshop and gym.
Tip. If using edpm lay it out over the roof for a while before glueing it down, in the sun it will heat up and stretch , noting it will get real hot so wear gloves when rolling back to apply adhesive. The advantage in doing this is once glued down in the heat it becomes shrink wrap tight in cooler weather when it tends to rain.
Post #1004325 16th Aug 2023 10:32am
excossack
Hi Ian.
Yes its an Apex roof made of T&G boards with a centre internal roof truss (10ft x 10ft shed)
The edge profiles will be standard wooden end boards for a shed and I was going to fold the rubber sheet under the edge and attach. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1004326 16th Aug 2023 10:47am
Ianh
EDPM can be used on Apex roofs and over T&G boards, however the sharp edges , especially at the ridge, eves and verges need to be rounded off by sanding and ensuring no nails / screws are protruding.
At the ridge I would be tempted to double up and glue a strip of EDPM that overhangs each side of the ridge by 200mm. Glue this down with the edge impact adhesive and use the impact adhesive again between that EDPM and the main EDPM going on top of it. The water based adhesive is then used to glue the EDPM to the roof boards and the impact adhesive 300mm around the perimeter.
Noting with the impact adhesive it’s instant grab so you need to get the fit perfect first time with no bubbles or kinks.
Post #1004334 16th Aug 2023 11:49am
excossack
Cheers for the advice, I will do some research into the best prices and work out the size required 1999 Defender TD5 110
Regards
John M0VAZ
Post #1004346 16th Aug 2023 1:40pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
All good advice from Ianh, I covered a pent roof summer house last year and as long as you follow the instructions you can’t go far wrong. Felt is for cheap garden sheds, anything more and EDPM is the stuff to use.
Post #1004406 16th Aug 2023 8:13pm
NickMc
The felt you get nowadays is total garbage too.
Post #1004434 16th Aug 2023 10:13pm
pjm-84
Hope not. Have 4400m2 of the stuff under a sedum room Thumbs Up
Post #1004440 16th Aug 2023 10:43pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
If you have the budget I would go for cedar shingles which are easy to lay straight onto a boarded roof and will have a 30+ year life.
They are light and as long as you use stainless nails will last longer than the shed.
Plus they look good !
Trevor
Post #1004453 17th Aug 2023 8:04am
excossack
EDPM ordered cheers all. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1004573 18th Aug 2023 9:11am
