![]() | Home > Td5 > 2002 TD5 - Hightlight issues with both old and new LEDs |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 335 ![]() ![]() ![]() |
If I was you I'd be checking the full run of the headlamp wiring from the switch forwards. It sounds like someone has modified the lighting circuit so the headlights run full time.
Look for a floating relay somewhere behind the instrument binnacle or in the engine bay. |
docperio44 Member Since: 08 Aug 2023 Location: Quebec Posts: 21 ![]() ![]() ![]() |
Thanks, yes that's exactly what it was. All set!
Was it carnage back there or was it easy to put right?
Some carnage -- tapped all the wires into the light switch then down into a mod within the fuse panel. a challenge but not horrible
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 967 ![]() ![]() ![]() |
If you have not already done so, you should install a headlight wiring loom to take the load off the switch. Glad you got your issue sorted.
![]() https://www.ebay.ca/itm/363852631160?fits=...BMqt_pnb9i 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
