Home > Maintenance & Modifications > Headlamp Adjustment Screws
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Hi all, does anyone know where I can purchase 4 of the headlamp Adjustment screws (the ones the headlamp ring slot into)?
The only ones I can find are £12 a pair which is disgusting for relatively small screws! A search of part number STC1614 for the kit reveals prices up to £20 Shocked
Thanks! Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #856208 15th Sep 2020 8:03pm
There seems to be quite a lot on eBay. Here's one example:
https://www.ebay.co.uk/itm/Headlamp-Adjust...SwK~RaMVSo
A search for Mini headlight adjusters brought up similar stuff, too. Darren
Post #856223 15th Sep 2020 9:50pm
ozzie1989
Thanks, I did see those but it says only up to 06 plus mine has headlamp levelling. Do you reckon they are the same screws though?
I probably need to check again as with the leveller I'm assuming only one adjustment screw is needed per side. Now: 2010 2.4 TDCi 110 Utility Wagon
Post #856236 15th Sep 2020 11:14pm
That date is a red herring as the set up for later vehicles is exactly the same as for TD5's.
It's two screws per headlight even with the levelling mechanism. Darren
Post #856265 16th Sep 2020 9:22am
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Same part number from 1999 onwards regardless of self levelling or not. Rgds.
Chris
Post #856270 16th Sep 2020 9:56am
ozzie1989
Thanks both that's great Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Post #856277 16th Sep 2020 10:42am
the_lincs_landies
Hi all, another thread revival (sorry!)
I have recently found that my adjuster screws just spin in place - if you put pressure in behind whilst unwinding then they do move with the adjustment, but the slightest pressure on the front pushes them all the way back in, so I think I need the bowls as well as the screws...
Does anyone know if the Wipac S6004 kit (bowls with bezel and fixings) includes the adjuster screws?
cheers
K
Post #1004048 14th Aug 2023 9:29am
