![]() | Home > Maintenance & Modifications > Nugget Stuff Air Intake Fitted |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
Is this the full monty £800 odd kit or the £250 option by the way?
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2279 ![]() ![]() ![]() |
Isn't the turbine thing in the original air box there to separate water out of the intake air and let it drain out of the air box ?
Only you mention water in the air box and say that you removed the turbine thing. Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 577 ![]() ![]() ![]() |
Just the £250 pipe thingy. I kept the standard air box with a K&N filter. |
There's a couple of devices in the original set up. First up there's a centrifuge with a drain then there's the turbine thingy at the entrance to the standard air box. As I mentioned when I had the standard set up water still made its way into the air box. There's a drain hole in the bottom of the box to let it escape. BTW when I say water gets in, it only dampened the bottom 1/5 of the box. Water is heavier than air so it falls to the bottom while the air goes up and through the filter. I've done a few more miles today and it's definitely smoother with more acceleration. I hope it also increases the MPG at tad too. |
Thanks good to know. I have a K&N or something similar from when I had my Alive tune done. |
Many more miles including a big camping trip now done.
The derestricted air intake makes a BIG difference. Definitely pulls better, smoother low down and picks up better. The best bit is that fuel economy has improved, getting 30MPG now! The downside is that I have to keep a keen eye on the speedo, it's too easy to do a bit faster than what's allowed. https://www.4x4overlander.com/product/nugg...ly-sealed/ |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
i have this kit on my 130, no snorkel just the kit for same reasons. after 2k miles my reckoning is other than piece of mind, and more noise, no other benefits on pickup or economy. Cheers
What engine 2.4 or 2.2?
Is the engine remapped? High flow air filter? Have you remove the "turbine thingy" from the air box inlet? Is there a high flow wing vent? All these add up. |
2.4
Yes Yes Yes No It made no odds to mine. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Interesting. It could be a 2.2 thing. I don't know enough about the differences between the two engines to comment on why.
