Home > Orders 2022MY (L663) > Defender 110 SE 200 delivery
Page 3 of 4 <1234>
LR Nuts
the VW camper boys have this also.
whilst inside the camper, the fridge box will slide open, into the camper walk area, then you lift the fridge lid.
when outside the 'slam' door is open and the fridge can slide outside and then open the fridge lid.
I have a trailer which has a similar operation. on the outside I open an upright locker door, gives me access the spirits optics.
When inside the trailer I open an internal (caravan style) wood door to get to the same compartment.
Dual access cupboard Thumbs Up
I'll see if I have photos of it.
Post #966437 2nd Oct 2022 5:07pm
cyberhusky
Luxembourg
I know that the double sided slide solution exists but the Dometic slide only works one way plus the slide rails are completely protected because they are in a closed frame. OTOH the Dometic slide isn‘t cheap.
A double way slide would not work in the new Def as the rear seats aren‘t completely flat. So the fridge would have to be mounted too high.
I could have fixed the slide directly on rails but this way the fridge would not be protected and I would loose place. 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #966447 2nd Oct 2022 7:40pm
cyberhusky
Luxembourg
Latest upgrades to my Defender
Finally I installed my lightbar and windshield cubes on my Defender.
The lamps were long enough on my workbench. I installed the OSRAM Lightbar VX1000-CB SM on the original LR roofrack using Powerful Uk clamps.
https://www.powerfuluk.com/vehicles/land-r...-l663.html
The clamps for the windshield lamps OSRAM Cube VX70-WD were ordered from Sailtek Motorsport in the USA.
https://saltekmotorsports.com/product/ditch-light-brackets/
Fitting instructions are on their page.
All these lamps are connected to an AUXBEAM 8 Gang Switch Panel controller from eBay from a Chinese seller.
https://www.ebay.de/itm/394243754778?hash=...R5in4pm7Yg
The controller is fixed to a self-made aluminium plate which is fixed in the motor bay. Just one cable goes from the controller inside the cockpit to the remote control panel. I still have to fix that one. I'm experimenting with a PLA 3D printed fixation.
All cables are connected via AMP connector (fiddling experience Big Cry )
Unfortunately I could not get both cables of the windshield lamps to rest connected together so I had to connect each individually. Now I use 2 buttons.
The DIY 3 mm aluminium plate fixed with 2 6mm screws.
The switch panel controller fixed to the plate with the emergency fuse and switch. Theoretically the included battery was to short so the switch isn't fixed at the moment. but works. I drove more than 1000 km with no issues. I will change this setup.
The remote controller cable routed inside the cockpit via the walled grommet.
Lightbar mounted…
cubes mounted ...
let there be light …
All lights on…… it wasn't completely dark yet...
Defender Headlights + cubes…
Only Windshield cubes…
and the illuminated remote controller
Lamps can be set to ON / OFF or WHEN PRESSED ON / WHEN RELESED OFF or STROBE MODE. All controllable via smartphone app too.
Plus it is possible to regroup lamps.
Instead of the windshield clamps I wanted the LAZER clamps which integrate into the A pillars but LAZER told me this is not possible with a snorkel mounted. Mad Would have been a better design. 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #1003442 9th Aug 2023 10:55am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Great job Bow down I have the lightbar and brackets from Powerful also and I have a similar switch but mine is a no-name one from Aliexpress (it was cheap though) I have had them lying around for a good while so must make an effort to get them fitted before winter. I like the way you have mounted the control panel and fuse to the aluminium panel, that's a great idea, do you have the rough dimensions of the plate you used please, I'll get a suitable 3mm aluminium plate ordered. I also need to figure how to mount the actual switch unit as I had intended to go through the big roundish grommet and mount it in a similar place to yours. Thumbs Up
 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1003475 9th Aug 2023 2:56pm
cyberhusky
Luxembourg
Hi Ian
I think your switch is the same as mine.
The problem with the position I mounted it, I have to demount it every time I want to connect another cable. It's a job of 5 minutes. One doesn't have enough access.
The lower part of the plate is bent 90° backwards for stability (not needed) but this way eventually water can flow down without sacrifying the switch (though it should be waterproof.)
For the holes red marks, I drilled t 6.5mm holes but had to redrill as there was missing some millimeters.
here's a pseudo CAD (made in Pages on my Mac)
Punching the grommet isn't so difficult if you go according to these instructions.
But You don't need to remove wipers and wiper shields.
https://cdn.shopify.com/s/files/1/2178/426...1630502139
The remote controller will be fixed to a 3D printed form.
Something like this still fiddling around where to put the holes.
A ready made plate is available here
https://saltekmotorsports.com/product/righ...0-bracket/
Please check this page for helpful ideas
Especially which fuse to take very important as the switch should only work when the motor is running.
https://landroverforums.com/forum/2020-def...934/page2/
I hope you do find the time to do it. It took me several days of work (not used to do things like that on an expensive new car Very Happy )
Cheers Manou 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #1003498 9th Aug 2023 6:10pm
cyberhusky
Luxembourg
I forgot 1 link
https://landroverforums.com/forum/2020-def...ed-115929/ 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #1003538 9th Aug 2023 9:46pm
Hairy Dan
Thanks Manou that's really helpful Bow down I had seen the Saltek brackets before but I thought he was only doing LHD ones, although the postage to the UK is rather steep so I was going to try and make my own and your drawings are helpful. Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1003545 9th Aug 2023 11:29pm
cyberhusky
Luxembourg
I payed 59 US$ postage plus 30€ taxes for delivery to Luxembourg for the windshield clamps which did cost 110 US$
If my 3D printed plate works I will post it here. 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #1003547 9th Aug 2023 11:41pm
Hairy Dan
Kielder 4x4 Safari
Post #1003548 9th Aug 2023 11:55pm
Moo
Ukraine
Great thread. Thanks. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1003575 10th Aug 2023 9:20am
cyberhusky
Luxembourg
Auxbeam Controller Holder
Hi everybody interested…
I have finished my Auxbeam Controller holder for the new Defender 110 (probably it works with the other models too)
I choose a 1.5mm thick aluminium plate, I wanted 2 mm but didn't find it. The 1.5 mm is enough an it is easier to bend.
I'm still working on my 3D printed version.
The plate is fixed with 1 screw only and 2 sided adhesive (3M). I wanted to use the 2 screws but apparently when cutting my card board it looked ok a the aluminium model was missing some mm.
But the construction is sturdy enough.
Here are the pics and plans LHD and RHD (for UK) versions.
Please print the plans in 100% size so they should be right to use. But don't drill the holes (red circles) only later when everything is double checked. For me at least measuring according to plans never works. So I install the plate and mark the places where to drill.
Those who have access to laser cutter can do it more accurately. I used a cutting disc, handsaw and Dremel.
Use the included holder to find where to drill the holes for the screws and cable.
Painted in black after double check everything…
Controller fixed with 4 included screws…
Reinstalled the rubber mat (had to cut away some part)
So here's the order number for the LHD version.
Covers reinstalled… finished
All lights work
Even group lights work now. Instead of pressing 2 buttons I just need to press either of the windshield cubes buttons. (Is set up via smartphone app)
Here are the plans for LHD and RHD cars. Please remember to print them 100% scaled. And the red holes aren't on the right places.
LHD version
RHD version
One last word:
This weekend I was at a medieval festival in Bouillon (Belgium) after sunset we drove to the highest hill in the region through dark off road forests.
The lights do illuminate everything: really very bright.
But the OSRAM VX1000 needs to be fixed with not just the 2 clamps from Powerful UK. There is some wiggling but not very much. 2 more clamps would be better.
Post #1004263 15th Aug 2023 5:14pm
Moo
Ukraine
Great job. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1004300 15th Aug 2023 10:49pm
Hairy Dan
Thanks Manou Bow down That controller holder looks ideal, I'm just about to order some aluminium plate Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1004303 15th Aug 2023 11:14pm
cyberhusky
Luxembourg
Voltmeter installed
At the same occasion I installed a Bluetooth voltmeter too. So I can see how well all my gadgets, lamps, fridge, Bluetti Battery, iPhones (wife and kids) eat up my energy.
It seems ok it's always around 14.26V to 14.5V while driving!
There's an app to check this via Bluetooth.
Post #1004337 16th Aug 2023 12:02pm
Hairy Dan
Manou, I promise I'm not copying you, I like to think of it as great minds think alike Whistle Laughing
I've had one of these on my old V8 as it doesn't do much mileage and I've just got one for the new Defender.
 Cheers Ian
Kielder 4x4 Safari
Post #1004342 16th Aug 2023 12:59pm
Page 3 of 4 <1234>
