Home > Maintenance & Modifications > Trailer socket bracket repair
spudfan
Ireland
The trailer socket bracket on the 2008 Puma broke, well really disintegrated, due to rust. I made a replacement from a zinc sheet I had in the shed. Nothing fancy but it'll do the job
 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1003378 8th Aug 2023 4:37pm
hank
Would you consider relocating it to the crossmember recess above? > 110 XS Double Cab
Post #1003383 8th Aug 2023 5:36pm
spudfan
Ireland
Possible I suppose but it was easier fixed as it was. The old bracket just rusted away. It is the standard Land Rover unit that plugs into the power above the rear member driver's side. There is just enough wiring to reach where it is now. To put it in the rear cross member hole I would need to cut the wiring to extend it to the hole. Easier to fix it in place where it was. 1982 88" 2.25 diesel
Post #1003385 8th Aug 2023 5:49pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
This might be a better long term fix
https://yrmit.co.uk/product/tow-bar-socket...-steel-lr/
Post #1003432 9th Aug 2023 9:56am
spudfan
Ireland
Yes that is a very nice inexpensive fix. As mine is zinc it will no doubt last me my time! 1982 88" 2.25 diesel
Post #1003434 9th Aug 2023 10:01am
Screbble
Mine disintegrated some time ago and I just happened to have a piece of stainless steel that fitted the bill.
Quite like the idea of relocating to the crossmember recess ‘next time,’ but methinks this will outlast me.
Post #1003438 9th Aug 2023 10:32am
spudfan
Ireland
On my adjustable tow bar set up, the slider plate wraps around the fixed plate so I would not be able to do this. 1982 88" 2.25 diesel
Post #1003447 9th Aug 2023 11:44am
