![]() | Home > For Sale & Wanted > [For Sale] 110 Td5 Station Wagon |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
All hilux's have low range (well the 4x4 ones do)
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1768 ![]() ![]() ![]() |
Yes but you're forced to use 4lo, which on tarmac means a load of tyre chirping and scrubbing when you're trying to reverse a trailer in tight spaces! If they had 2lo it would be spot on
There's a hack for the Mk7's (not sure about the Mk8 which I have) to enable the 4 low 2wd, and also to keep the traction control off over 20mph or whatever stupid low speed it cuts out at.
All that aside, I'm loving mine. |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5235 ![]() ![]() |
jim what did you use for the towing electrics, looks like a later plug? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
It had a military 12 pin NATO socket on it (as the main thing I used to tow was my old GKN 3/4 ton trasiler and later on my Penman.
I made an adaptor to convert the 12 pin to a civvy 7 pin socket. |
