Home > Maintenance & Modifications > Defender 110 PUMA - Front swivel hub advice |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3421 |
Btw, on a Puma, it is better to ensure that the swivels keep the grease properly in, and keep the water and crud out. A failed CV joint on a Puma means a complete new half shaft. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
2nd Aug 2023 3:42pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17443 |
Be aware that the assembly you will be pulling out is pretty heavy. I have in the past found that putting the wheel back on and resting it on a shovel helps, since you can drag the shovel away from the vehicle and withdraw the assembly most of the way without actually having to hold it off the ground.
An offspring's skateboard (if you have an offspring) might be even better. |
2nd Aug 2023 4:15pm |
BaCoNMX6 Member Since: 22 Apr 2022 Location: Amsterdam Posts: 63 |
I am hoping the method i was used to with patrols and landcruisers (i.e. giving them a slight sanding to remove the highs) will give me a few extra months too.... |
2nd Aug 2023 4:57pm |
Yeh thats a great idea as no doubt that lump of metal is heavy. Just hoping that the recently replaced rod ends means they are stuck in like a MF!! |
2nd Aug 2023 4:58pm |
