Home > Maintenance & Modifications > Sound deadening
Poulstonb
Sound deadening
Evening all
Ready to start sound deadening my 90 TD5 station wagon
I’ve ordered silent coat matting ( 110 pack so I’ve enough to cover roof, all of rear and front.)
Also 4 m2 of dodo matting 8mm. ( plan on doing rear tub and roof ).
Currently my front carpet doesn’t go under the seats so going to change for one that does .
Anyone any tips
TIA
Post #1002319 30th Jul 2023 9:01pm
edward
Good luck! I did the whole (floor area) of my 110 double cab earlier this year. I used skinz and then a layer of dodo barrier mat everywhere plus silent coat noise buffer in the footwells.
It has made a huge difference. Haven’t done the roof or doors yet. I also used flashing tape to seal all the skinz and flexi sealant if I could still see any daylight. I did the Billing course this year and not a single drop of water got in - so I also think the advantage of sound proofing is water proofing!
My only tips would be get a good sharp Stanley knife. Be prepared it will take 3 times as long as you think and buy loads of spray adhesive for the dodo barrier and carpet.
Post #1002321 30th Jul 2023 9:42pm
Poulstonb
Thanks I’m prepared for a fight with it
Post #1002325 30th Jul 2023 9:49pm
edward
It’s actually quite fun…. Just take your time.
My other tip was remember where the seat bolt holes are as you go! If like me you do 2 or 3 layers you can suddenly find yourself underneath poking holes into the second row seat bolt holes to re-locate them under all that matting.
Post #1002327 30th Jul 2023 9:54pm
west4x4
It’s a satisfying job to do. Sharp knife and take your time. I used a glue called “grabfast” it allows you to peal up and restick
Post #1002332 30th Jul 2023 10:50pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
West 4X4 - I like the "lawn" in the back of your Landy. Is it easy to mow? Laughing
Jim
Post #1002338 31st Jul 2023 4:49am
Shafski
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Morning.
I did my 110 a few months ago. Bought the 110 kit.. then more! I used scissors rather than a knife to cut. The 6mm Dodo I used (also everywhere) was stickier than a sticky thing.. so certainly no extra glue needed there. What tool the time was the rollering. That makes a huge difference to the fit.. and it’s quite satisfying as you see it from.
3 layers in the doors took me a day.. 2 laters on the tunnel.
I’ve just the bonnet left to do.. but already it’s an incredible change, especially at speed.
Good Luck! Shafski
_________________________________________
2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E
Post #1002346 31st Jul 2023 7:04am
LR90XS2011
Well worth doing mine is quieter now than my everyday fiat panda.
We can talk normally at 70, the radio volume is at least 25% lower for the same effect. DEFENDER 90 TDCI XS,
Post #1002347 31st Jul 2023 7:10am
edward
Shafski wrote:
Morning.
Good Luck!
I’d be interested to hear if you think the bonnet makes a difference. I hear differing opinions especially with the puma.
Post #1002361 31st Jul 2023 9:21am
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I did the bonnet of my 2015 2.2 TDCi and it made a huge difference. It totally removed the diesel rattle. I took the bonnet off to stick down the Dodo matt stuff.
For the cab I used Wright Off Road matting. Tuff stuff to work with but again made a big improvement to the noise. I don't need to adjust the radio volume from idle to motorway speeds.
Post #1002402 31st Jul 2023 2:37pm
jimmyvonk
United Kingdom 2004 Defender 110 Td5 CSW Epsom Green
I have just fitted some used TD5 Disco rear engine and bell housing sound proofing panels and it made a big difference... so much so that Mrs JVK even commented. Very Happy
LBH100360 for the rear of engine and not sure on the bell housing - lots on ebay
Post #1002920 3rd Aug 2023 8:53pm
90GTR
 2016 Defender 90 V8 Petrol Works V8 Auto Santorini Black
Has anybody fitted the Noise killer kit?
I know this is bad of me, but I've recently found a complete unopened set in storage. It's pretty hefty packaging so feels substantial enough.
Dynamat along with XS carpet has been sufficient enough mind you.
Post #1003146 5th Aug 2023 9:03pm
Screbble
I fitted the Noisekiller kit approx. 8 - 9 years ago. Made a big difference. Included the engine ‘blanket.’
Didn’t really know about Dynamat at the time - but that’s clearly the preferred brand/product.
Don’t hear much about Noisekiller these days…
Post #1003162 5th Aug 2023 10:36pm
