Home > Tdi > Cost of 300Tdi timing belt change
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi all
I have changed the timing belts on 200Tdi and 300Tdi Disco’s albeit back in the 1990’s. Before I bite off more than I can chew I thought that I would ask on here what the going rate is for a timing belt change on a Defender 300Tdi is at a garage these days?
Anyone had one done recently?
Jim
Post #992795 15th May 2023 10:30pm
TomB8
United Kingdom 1994 Defender 110 300 Tdi HT Arles Blue
I can't advise on cost as I never had mine priced. Probably a couple hundred plus parts though.
If it helps, I did mine myself, having never done anything like it in the past (sound's like you have, so you should be in a better position than I was) and it wasn't too hard. The worst bits were 1. getting the fan off (mine had not been off for 14 years) I had to fabricate the tool sold by land rover - covered in a video by britanica restorations, pretty easy with a bit of 6mm thick bar and a grinder. 2. the crank bolt, I just bought a big makita impact, but the proper tool is readily available for not much money. As I'm sure you know, getting it off is easily achieved, but doing it back up is much harder.
Post #992804 16th May 2023 12:27am
Jeebs
United Kingdom 1995 Defender 90 300 Tdi HT Barolo Black
Friend of mine did mine for mates rates, so I can’t give you an accurate cost. It’s worth noting that if you fit an improved kit that there’s a bracket needed for the injector pump.
Post #992814 16th May 2023 8:54am
jim4244
Tom, when we owned Disco’s in the 1990’s I had a welder fabricate me a tool for the crankshaft pulley. Since then we have moved to NZ and back and 4 other house moves and it has “dissapeared”
Hmmmm…… I tackle most jobs my self and whilst the timing belt isn’t technically hard it is a lot of bloody work for an old codger!
Jim
Post #992815 16th May 2023 8:56am
Litch
If I was still in Bedfordshire (Cranfield) I would have offered to help as I have all the tools (crankshaft locking tool, timing pins, puller, fan spanner etc) and have done my own 300TDi belt three times now.
As it is I moved to Oxfordshire last year so a bit too far. Crying or Very sad
I must admit, having the correct tools to hand makes it a breeze. I made the decision the first time I did it to buy them rather than making do and improvising, made life much easier and they have now paid for themselves.
Last time I did it (2021) I decided to also replace the water pump, P-gasket etc. Not certain if it was worth it as everything was still in fine condition (2004 engine, <60K miles from new) but it added very little time to the job. Always do the tensioner and seals though.
 ONE LIFE, GET IT!
Post #992843 16th May 2023 1:37pm
familymad
You are a very handy man to know being just in Bucks…. Whistle 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #992923 17th May 2023 7:58am
TomB8
Jim
Jim,
Yes, it is time consuming. My thinking was, if I buy the tools I can change the belt as often as I like for free. I would say a decent impact (quoted as 1,000Nm+) is invaluable for making other jobs on a rusty old car easy. By the time you've deducted the cost of the correct tool and cost of paying someone to do the job, the nice impact is free! Very Happy But if you're not up for doing it that doesn't help you.
Sorry, none of this answers your question. You may have to call around local 4x4 specialists. I can give you details of the chap I use if I do need to have work done, but he is in Aylesbury.
Post #992944 17th May 2023 10:58am
Procta
Re: Cost of 300Tdi timing belt change
jim4244 wrote:
Hi all
Jim
back in 2018, i had one changed, and i paid nearly 300 quid. That was me supplying the parts, and the garage is a specialist, but a very expensive one too. So id ask a very decent garage for a price and supply them the bits. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #999145 8th Jul 2023 2:13am
NickMc
Do you take your own steak to a restaurant Procta? Whistle
Post #999193 8th Jul 2023 1:53pm
Procta
Yeah i do Razz the garage that did the belt change, are well known for charging stupid prices for bits. If i hadn't supplied the parts, id have been looking at a 500 quid bill.
They wanted to charge me £120 to put the TD5 on diagnostics, got it done for £25, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #999262 8th Jul 2023 8:46pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
In my country that's a lot of money.
I do my own work and did a whole service (filters, oil and timing belt) for about a 3rd of the £300.
Post #999323 9th Jul 2023 2:37pm
donmacn
I did a 300Tdi belt a month or so ago. First time I'd done one of them, though I had recently done similar on things as diverse as a 1.2 Renault Clio, and a 4.0 V8 Range Rover. I also did the water pump and P gasket as this vehicle is due for a long run in warmer climates in the next 2 or 3 months.
I did have a big cordless impact gun, and the special crankshaft tool though, and the radiator was still off, but still I didn't think it was particularly difficult. If/when I do this again I would seriously consider removing the radiator again. I know it's not strictly necessary, but it does provide so much more access.
The only problem we had was that someone had loctited-on the crankshaft timing belt pulley. I had to fabricate a puller for the small M5 threads and I think trying to do that without removing the radiator would have been a real pain.
On the question of the fan removal tool, I bought one once and it was made of really soft cheese. The jaws opened almost straight away. At that point I took a proper 32mm spanner and attacked it with a grinder to make it thin enough to get between the fan and the viscous hub. Still plenty of meat on it to get the nut shifting, and in fact to still use it as a normal spanner. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #999459 10th Jul 2023 1:22pm
Litch
Jim, have PM'd you. ONE LIFE, GET IT!
Post #1002212 29th Jul 2023 8:53pm
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
As usual, everything is a half day job till you realise someone (thanks MOD!) used Loctite on the visco.... Banging Head
Post #1002217 29th Jul 2023 9:58pm
Litch
Shameless advertising here but the timing kit and locking tool I mentioned earlier is now for sale (along with all the other bits used to change the timing belt).
Sold my 90 last week so everything is now being sold, see my ad in the For Sale section. ONE LIFE, GET IT!
Post #1002843 3rd Aug 2023 12:24pm
