Home > Td5 > Clicking noise on full lock?
excossack
Recently noticed that on full right lock and sometimes on left lock I get a clicking from what appears to be the front drivers wheel.
Not had time to inspect that area yet...But open to suggestions.
My thought is CV joint? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1001816 26th Jul 2023 11:15am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Yup classic CV joint noise Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1001817 26th Jul 2023 11:21am
rallysteve
likely CV joint. Before dismantling it might be worth checking the endfloat/shimming of the splines into the driveflange. If there is a lot of endfloat here it can cause the CV joint to locate too far inwards and bind up on lock.
Post #1001818 26th Jul 2023 11:22am
excossack
I did think CV.. Sad
End-float. I didn't know the drive flange had shims. Are the shims behind the flange? 1999 Defender TD5 110
Regards
John M0VAZ
Post #1001820 26th Jul 2023 11:26am
rallysteve
Sorry my description wasn't great! The shim is between the circlip and driveflange on the outside (under the rubber cap if you have original style flanges). 02' 110 TD5 Double Cab Rebuild Thread
Post #1001821 26th Jul 2023 11:38am
excossack
Oooh.. cheers. Not sure if I have noticed a shim there.
Still have original drive flanges - certainly the standard type 1999 Defender TD5 110
Regards
John M0VAZ
Post #1001824 26th Jul 2023 11:44am
geobloke
Here you go John
Number 12 https://www.lrworkshop.com/diagrams/land-r...6_52605#12
I have this on my list to check since I now have a DTI sitting downstairs ready to do the rear diff centre.
This is the instructions:
End play should be between 0.08-0.25mm Thumbs Up
EDIT: coming to think about it if you do not have a DTI then when we meet up we can check yours in the car park Thumbs Up
Post #1001831 26th Jul 2023 1:14pm
excossack
Cheers Guy. I do have one...but currently in a box in the F-i-L's garage as I am rebuilding the shed...
21 supermarket stackable crates currently house the contents of the shed! 1999 Defender TD5 110
Regards
John M0VAZ
Post #1001838 26th Jul 2023 1:52pm
geobloke
Yikes Shocked That is one full shed
Post #1001840 26th Jul 2023 2:00pm
excossack
Yup. Its only a 10x8.....new one 10x10.... 1999 Defender TD5 110
Regards
John M0VAZ
Post #1001841 26th Jul 2023 2:10pm
geobloke
Oooo an extra 2x10 space. Sounds like a decent sized work bench to me Thumbs Up
Post #1001845 26th Jul 2023 2:21pm
excossack
Hope so as well. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1001853 26th Jul 2023 3:14pm
