Home > My Defender > New member with UK NAS AND 50TH Development Car
Page 1 of 11 123 ... 91011>
sasdiscos
Hi all,
I’ve just purchased a defender 90 landrover test mule on a Q plate.
It was originally built by landrover in 1995 as a NAS spec development car.
It was used to prototype the NAS car before it was put into production and sent to the USA.
Following on from this, landrover decided they wanted to make the 50th. The car was then converted to RHD from LHD by landrover, uk air conditioning fitted ect, the hard top put on and again used to prove the concept of the 50th.
Shorlty after this in 1999 it was scrapped by landrover and re registered on a Q plate, now a 1999 registered car.
It was then converted completely to gas lpg, and this is where my project lies……
I really need some info on what to do and what parts to source. I’m used to working on derv defenders but not petrol.
My plan is to get the car back to factory spec, lower it back to standard, put back the gems ecu or a tornado kit. Blow it over in standard NAS paint and have as close to a 50th as I can get, pretty much identical inside etc.
It has no fuel tank, sender, pipes, pump, wiring, engine harness, just runs on gas with a dizzy.
So where to start, fuel tank would be good and fuel pump I suppose.
I had thought about carbs as the dizzy is there but not sure, I would like to get it back to factory with the efi if possible. However, carbs may be a temporary fix so I can drive it about.
I plan on using RPI engineering, but cant get it there due to lpg disappearing ff the face of the earth.
So my plea to you people out there is can you help with any part numbers please?
Many thanks in advance. Steve
Post #1001255 22nd Jul 2023 1:03pm
Welshsurferdude
Wales
Ooooft now thats a special one!
Thumbs Up Thumbs Up Thumbs Up 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #1001271 22nd Jul 2023 2:48pm
NickMc
I had a td5 02 facelift test mule much the same story, they usually have hand written numbers on parts to show which “mule” they are.
I would say keep it original or you will ruin the “history” of it. There used to be a guy on one of the forums had a soft top NAS mule I think.
Post #1001278 22nd Jul 2023 3:21pm
sasdiscos
Hi yes, want to put back to original, get rid of the lift etc.
Did the brakes today as they were all knackered.
Fixed 2 oil leaks.
Found massive holes in the exhaust.
Need to fit a new one but don't know if I should fit cats or not.
Looking at this.
It does have euro 2 emissions on the log book so guessing ill need them, but don't know what to get.
Its got through emissions ok with what it has now, similar to the one pictured, but its on lpg, so assume the emissions will go up when I put it back onto petrol.
I will be ripping the gas out in a month or so so need to source all the parts.
Hoping there will be a wealth of knowledge on here.
Looking forward to the challenge.
Steve
Post #1001283 22nd Jul 2023 3:38pm
NickMc
Post #1001286 22nd Jul 2023 3:43pm
sasdiscos
Yes, indeed Nick, thanks.
However, Thats the bloke I got the car off.
Thought he might have told me he had it when I brought the car, knowing full well I intended to remove the LPG.
I think a td5 tank will do the job as they are supposed to be the same. Im reluctant to give him 500 quid and drive all the way to b, ham again.
Steve
Post #1001291 22nd Jul 2023 4:03pm
NickMc
Sorry I looked the other day at tanks and saw it, just realised he has the missing seats and bits for sale too Rolling Eyes
I have a few plastic tanks for sale if you need one too. They’re not quite the same though. I think was it maybe Keith Gott had a few NAS things for sale in the past…
I would say it has slipped through the net and probably should have been crushed by Land Rover, there’s been a few cars come out like that.
Post #1001297 22nd Jul 2023 4:39pm
sasdiscos
Yes.
I don't know if its a good or a bad thing.
Im just going round in circles at the moment.
First priority is get the exhaust fixed so I can get 12 months MOT on it.
This buys me some time.
Then starting with the fuel tank and lines etc work my way p to the engine management.
I d be very interested in what any one has to sell, providing its what I need.
The td5 tank looks identical, I just wonder if a 110 petrol fuel sender will fit the tank?
The other option is to get a tank made I suppose.
Ive asked a chap on eBay about exhaust manifolds, I think that discovery 1 v8 manifolds are the same.
This is going to be a lot of trial and error and this is probably why the last guy gave up.
Once the gas tank is empty I'm screwed any way because there are no lpg stations near me to fill up.
Do you know if the exhaust system from the 3.5 Im looking at will fit, it looks identical.
Thanks, Steve
Post #1001300 22nd Jul 2023 4:56pm
NickMc
Can you post some more pictures of under the bonnet or the exhaust system that’s currently fitted? it might help people identifying parts.
It’s a rare vehicle and as you’ve said a Mule so different parts will be on each one and stuff that’s very sought after, just part and parcel of owning such a thing. Rare parts unfortunately probably means expensive parts.
I’d get a parts manual for the NAS and V8 50th and compare it to yours.
You can modify and fit various different discovery “classic” or D2 v8 senders to fit with a little modification of the tabs, just like the tdi senders.
I would find a V8 50th owner and get some pictures, I think there’s some on here, there used to be a 50th owners club too.
Post #1001304 22nd Jul 2023 5:29pm
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
This may be of help:
https://www.defender50th.co.uk/
Post #1001306 22nd Jul 2023 5:45pm
sasdiscos
Thanks Mr Fox but not much going on over there.
Im guessing this will be a long slog, shame because I'm an impatient Censored . Laughing
Post #1001308 22nd Jul 2023 5:52pm
sasdiscos
Here are a few more pics.
Its just started pouring down so can't gat any more till it stops.
Thank you for your responses guys, gives me some hope.
As you can see it has a dizzy currently, suppose it was easier for the complete gas conversion.
The exhausts are 4 - 1 manifold type, no cats. (but think I may need them refitting)
No wiring as far as I can see.
I am in talks with RPI engineering with her the ecu and sensors etc.
However there is the option to go carbs as the distributor is there.
Post #1001309 22nd Jul 2023 5:57pm
Mr Fox
It is a VERY quiet forum but there are some clever guys on there and a lot of of knowledge. Also may be worth searching old posts and putting up a wanted ad for parts.
Post #1001324 22nd Jul 2023 8:29pm
sasdiscos
Thanks, I’ll give the wanted ad a try that’s a good idea.
If only I knew what I needed.
Steve.
Post #1001325 22nd Jul 2023 8:36pm
JOW240725
What a great 90 with an interesting history. Good to see its being well looked after. Thumbs Up James
Instagram @suffolk_rovers
Post #1001329 22nd Jul 2023 8:55pm
