![]() | Home > General & Technical (L663) > Wearing hose issue |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
https://www.defender2.net/forum/topic86441.html
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Thanks Martin Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
chrispuk Member Since: 22 Nov 2021 Location: Wirral Posts: 13 ![]() ![]() |
Yours looks fine with a clear gap. On mine the hose is right up against the sharp edge of the air filter housing (? I think). Have put a couple of stainless hose clips round it as was starting to chafe.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2945 ![]() ![]() |
Yours clearly has a modified air intake canister, with a flat section to avoid touching the hose.
Here's mine, with the hose touching the canister. ![]() Click image to enlarge |
Today mine went in for this to be rectified.
lt's come back.....exactly the same!! l thought they would fit the modified canister but they've just replaced the hose and "re routed" it. But it's still touching the canister. l'm not taking it back again, it took two months to get an appointment and l was without the vehicle two days. l will keep an eye on it, the new hose has an armoured sheath but l think the old hose had that. l may have to buy and fit the canister myself if it starts to chafe. Although it will be a long time before it actually rubs through the hose, if ever. |
I’ve put a couple of stainless steel hose clips round mine where the hose chafes against the sharp plastic edge. Think it should protect the hose indefinitely?
Yes that will certainly help.
You can also carefully remove the edge of the canister with a craft knife (about 2mm of the plastic edge can be removed before you get to the actual seam, and it does make all the difference) |
Modified part now available. lt's a recall/warranty issue but they couldn't commune for months so l've bought the part to fit myself.
Modified part now available. lt's a recall/warranty issue but they couldn't do mine for months so l've bought the part to fit myself.
![]() Click image to enlarge ![]() Click image to enlarge |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2673 ![]() ![]() |
Do you have the tech bulitin number? Mine is going back into the dealers shortly so would like to get them to fix it properly. Last time they changed the hose and the tech bulitin they were operating from just said, loosen bolt, relocate air resonator further back, tighten bolt. So mine now has a 10mm ish gap but I'm not 100% confident in this solution 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
l ended up buying and fitting the part myself.
lt's fairly easy to fit although you'll need a 1/4" ratchet driver to loosen the bottom hose clip, due to access issues. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
Someone I know had a similar issue with component/pipe chaffing on an other vehicle. His solution? Well he took the lid from a sardine tin, the ring pull type, bent it around the hose where the component was rubbing and secured it with some cable ties as a temporary measure. The "temporary" measure was still in place when he sold the car some years later but it worked. Wonder what the maindealer would say if your Defender landed in with this "temporary" fix! 1982 88" 2.25 diesel
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1443 ![]() ![]() ![]() |
"That's not an authorised repair method"
Then they'd charge you £200 for looking and checking. |
Maybe they would not notice....
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
