Home > Td5 > Engine observation after ignition |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1086 |
No not normal. There is no delay after starting for the engine to produce power. The lack of power going up hill might be normal as the Td5 needs a few revs to produce power. Keep it above 2500 to get decent up hill power.
It's not a terribly complicated engine and you need to do some trouble shooting. Check for correct fuel pressure. Check turbo pressure. Is your air mass meter working correctly? Are your injectors dialled in correctly. EGR working correctly? |
20th Jul 2023 5:08am |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 899 |
Try unplugging the MAF sensor before you next start your Td5. A dead MAF can cause 30s of a lack of power upon start-up. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
20th Jul 2023 12:28pm |
What they said... The MAF can produce so weird running conditions. Unplug it and re-try. If and when you need to replace it only buy VDO or Genuine LR as they have less problems.
20th Jul 2023 2:09pm |
