Home > Puma (Tdci) > Optimill QR boss on 2015MY - any problems?
albatross
Apologies if this is answered elsewhere but I've searched and cannot find an answer.
I'm thinking of going for the optimill quick release steering boss mainly for security. However I've read that the steering wheel was changed for 2015 to support dynamic stability control and the indicator cancelling mechanism was changed in the process, see http://www.web-rover.co.uk/articles-steeringwheels.html
So has anyone fitted the Optimill boss to a 2015 model and, if so, do the indicators cancel OK? Is the DSC OK? any unforeseen side effects?
If necessary, does anyone know of an alternative that has resolved the DSC issue?
Post #709718 29th May 2018 10:55am
Sulisuli
Hi welcome to the forum. I have the Optimill quick release on my 2015 xs hardtop and no problems whatsoever with the DSC or indicators cancelling. It’s a very nicely engineered piece of kit and works really well. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #709781 29th May 2018 4:57pm
albatross
Thanks Suli, that's reassuring! I didn't fancy forking out £500 and regretting it.
How do you get on with the smaller steering wheel? That's assuming you went with a 35cm Momo or similar
Post #709811 29th May 2018 7:23pm
Grenadier
Small steering wheels are a joy, IMO. Fit one and it soon becomes 'normal'. Then use or borrow a Def with a standard wheel and wonder how on earth you got on without it. Quick, easy and relatively cheap upgrade that does make a difference. One tip, if you go Momo, do not buy their 'deep-dish' versions has they pull your hands too far away from the indicator stalks but even more annoying is the cramped reach. Gets very close to your body, possibly more so with the QR boss. Stay with the flat versions and you'll be fine. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #709814 29th May 2018 7:41pm
Sulisuli
£500 what are you planning to buy!! I had a momo Nero which was nice but swapped it for a Startech which is very very nice. What steering wheel are you thinking of getting? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #709821 29th May 2018 8:04pm
albatross
Ah yes, maybe I was a little ambiguous Very Happy , the aforementioned £500 included the QR boss, wheel and swivel lock and I rounded up a bit for good measure. Mind you, from what I can see you get pretty close with just the wheel if you go for startech! At that price people may break in to steal the wheel and leave the landy alone...
Post #709825 29th May 2018 8:12pm
Sulisuli
Very true but the Startech is stunning. The swivel lock is a great piece of kit, the docking station is very useful too, do a search on the forum for ideas where to mount it. I have sent you a pm. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #709826 29th May 2018 8:14pm
albatross
Thanks too Grenadier, 35cm seems awfully small...it's only a bit bigger than the wheel on my Lotus! So it's good to get feedback from people who have tried it.
Post #709827 29th May 2018 8:16pm
Furball
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Re: Optimill QR boss on 2015MY - any problems?
I too have been searching, so thought I'd resurrect this. I have a post 2015 (with DSC) and have fitted a an Optimal QR boss. I will of the moment assume you and probably others now have done this. Question for all; did you need to use the small pins for self cancelling on the 'DSC model'? My indicators won't self cancel, but very occasionally they do. TIA
PS, I would check the OEM steering wheel but not with it - in storage.
Post #1000223 15th Jul 2023 9:48am
90 Dreamer
Not sure I used them and all works perfect
Post #1000428 16th Jul 2023 7:07pm
C&M
maybe slightly different as mine is a Nov 2014.
but that said, the boss ( as long as you get the right spline count) is very easy to install and I didnt bother with the pins. seems to work fine without them.
the swivel lock is brilliant.
and I second the Startech, make such a different and looks the part with the Land Rover name on it. Defender D250 HSE
Dender 110 XS - sadly gone
VW Polo
VW Caravelle - Gen 6
Post #1000522 17th Jul 2023 12:32pm
discomog
I have a MY2015 XS Station Wagon (left the factory April 2015). Optimil QR boss and swivel lock was a straight swap for standard factory fit wheel. No problems with indicators not self cancelling. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #1000525 17th Jul 2023 12:44pm
