Home > General & Technical (L663) > "P" and handbrake
Page 2 of 3 <123>
lightning
okay so the "P" button engages the transmission brake, which l always do when leaving the vehicle.
The handbrake is independent of this, but engages automatically when you leave the vehicle.
But you don't know it has because the warning light is the same one as the transmission brake.
Unless you didn't engage the transmission brake in which case the warning light indicates that the handbrake has engaged.
And you get the "transmission brake not engaged" warning
(takes a breath)
So long as that's the case l will just let the vehicle get on with it.
Post #998372 3rd Jul 2023 12:20pm
EPB is Electronic Park Brake or 'handbrake' in old money.
You can apply the handbrake independently of the transmission brake (P or Park) but if you apply the latter then it automatically applies the former. Darren
Post #998374 3rd Jul 2023 12:32pm
Retroanaconda
There is no warning light for the ‘transmission brake’ (i.e. being in park) - the red light with the P is just for the EPB. If the transmission is in park it will say P in white on the dash which is your indicator for that. If you manually put the car in neutral and then manually apply the EPB you’ll get that warning, to remind you it’s not in park.
In practice the car is either in park, drive or reverse (unless using manual mode), neutral is not used much. As such the EPB operation is entirely automatic and required no input from the driver. The only time I use neutral is when engaging low range, at which point your foot is on the foot brake.
Post #998386 3rd Jul 2023 1:17pm
I can't help but think it was so much simpler in the old days. A handbrake lever and a transmission selector, entirely separate and entirely under the control of the driver.
Strangely most (but admittedly by no means all) drivers seemed to cope with the "complexity" back then without any form of help, and it was also possible to release the brakes and transmission locks without power if you had to push the vehicle, for example if the built in Lucas "Prince of Darkness" gremlins struck in a live lane.
Oh, the good old days*. Life was so much simpler then!
* The days when "intermittent wipe" just meant that more often than not the wipers didn't work.
Post #998393 3rd Jul 2023 1:35pm
lightning
Yes my old Defender TD5
Great big handbrake lever with a warning light that sometimes worked and sometimes didn't. But it always held the vehicle (except when oil leaked in to the handbrake drum)
Or if one wheel was on ice, in which case you needed to leave it in gear and engage the differential lock, which wouldn't always go in unless you started the engine and moved it a bit.
There was a light in the dash for that too.
Post #998403 3rd Jul 2023 2:32pm
medallionno3
It’s actually very simple
I’d you put the gearbox into park it engages the park pawl in the transmission and the electric park brake
If you apply the electric park brake only it does just that - there are use cases where you may want this on but vehicle in Drive such as on steep hills off roading
If you apply electric park brake but don’t out transmission on P you will get a warning if you try to exit the vehicle as the vehicle is on Drive
Post #998464 3rd Jul 2023 8:10pm
lightning
Or neutral?
Post #998594 4th Jul 2023 4:55pm
Cheshire110
indeed, it won't let you leave the car in neutral (even if the EPB is on) unless you are very creative
I needed to tow myself out of a mild off-road pickle on my own and ended up having to put the car in neutral and disengage the handbrake through the window Cheers, David
Post #998642 4th Jul 2023 7:46pm
lightning
l suppose on most circumstances that is a good thing. But in over 150,000 miles of old Defender driving l never once forgot to leave the vehicle securely parked. As in handbrake on, transmission in gear if necessary.
lt's just common sense. But when everything is automated l suppose people expect it.
Post #998672 5th Jul 2023 7:05am
lightning
Our 2020 Jimny is a lesson in how it should be done.
Four positions on the headlight stalk, which is an actual switch, so it stays in the position it's set to. Don't want auto headlights? Set to "off"
Off (DRL's on)
Auto
On (sidelights)
Headlights on
All the lights are LED (and the headlights are superb) except the DRL's which are ordinary bulbs.
So, as they are always on if you eventually get a failure the cost to replace is £3 for a bulb.
Post #998764 5th Jul 2023 6:43pm
XplusYplusZ
...I just press the "off" button...
Post #999476 10th Jul 2023 1:12pm
lightning
But then it turns itself back on
Post #999557 10th Jul 2023 8:28pm
XplusYplusZ
I double and then triple checked yesterday... but am still super paranoid..
It seems that I can pull into a parking spot, stop using the footbrake, press 'OFF', and it changes the gear to 'P' and applies the ((P)) Handbrake and turns the engine off. It doesn't ping, pong or complain...
I don't know if the difference is that I have the 'autohold' feature enabled and you guys dont?
Post #1000123 14th Jul 2023 3:37pm
Retroanaconda
Auto hold just applies the foot brake when you stop, it’s not related to the parking brake. It’s on every vehicle - though most turn it off as it is very annoying.
Post #1000131 14th Jul 2023 4:23pm
lightning
l am in the minority in liking the "Auto hold"
The only time it can be a pain, is in slow moving stop/start traffic. At all other times l think it's great.
Post #1000159 14th Jul 2023 6:13pm
Page 2 of 3 <123>
