Home > Td5 > Factory TD5 rev counter plug and play? |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 488 |
Yes, for the grey 14-way male / female instrument harness connectors (C1048 / C1040).
I can also supply them pre-crimped to whatever length of cable you require. PM me Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
5th Apr 2024 7:12pm |
110Matty Member Since: 20 Apr 2023 Location: Somerset Posts: 104 |
I thought I had the white / slate wire to pin 14 of the plug, as it turns out I don't ! I checked the black plug at the ECU and it appears pin 19 is also vacant - just a very small grey rubber plug (7 across on middle row, next to pink i think). I have a rev counter from Rimmers (installed, lights up and does a self test), that included the white/black wire for the ecu feed. Having up loads of pins on other connectors, I would very much like to avoid doing at the ECU. Can someone explain the orientation that the pin needs to go in so it clicks in place nicely? I have no ABS / TC etc by the way. Many thanks. |
23rd Apr 2024 1:04pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6491 |
Key off.
Remove black connector from ECU. Remove the white plate on the front of the connector (should virtually fall off) Remove blanking seal from pin 19. Hold the connector with the clip on the top, then the wire terminal should be fitted with the crimp visible on top and pushed into place until it clicks. Replace white plate. Replace connector to ECU. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
23rd Apr 2024 1:41pm |
Fantastic Martin. Done and rev counter test working, just need to route cable back to dash properly.
Really appreciate the fast, knowledgable and accurate response to help me out. Brilliant. Thank you, Matt. |
23rd Apr 2024 2:14pm |
