Home > Td5 > Factory TD5 rev counter plug and play? |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2201 |
You will need to run a cable from the ecu. I believe ABS vehicles have a cable already wired to the correct pin but it doesnt go all the way to the dash. 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
21st Feb 2024 11:55pm |
Zimblewinder Member Since: 12 Jan 2019 Location: Geelong Posts: 32 |
just so you know my 2000 130 also had the grey wire from #19 pin, to the block behind the dash binnacle; just not to the tach.
22nd Feb 2024 8:03am |
2hel Member Since: 28 Nov 2022 Location: Essex Posts: 171 |
That's typical I was hoping to avoid that by having part of the loom. Nevermind!
I don't think my 2003 TD5 has ABS so hopefully the pin 19 is spare. In my quest for OE finish I assume I can run the cable from pin 19 and then plug it into the back of wherever this black cable meets the harness behind the dash? I.e Trace the cable circled to the connector on the dash loom and should be blank on the other connector? Haven't explained that well but hopefully makes sense Click image to enlarge |
22nd Feb 2024 8:04am |
just so you know my 2000 130 also had the grey wire from #19 pin, to the block behind the instruments; just not to the tach.
I guess the grey was for ABS?
22nd Feb 2024 8:05am |
Biscuits Member Since: 27 Mar 2023 Location: Kent Posts: 28 |
I have to fit an OE rev counter to my 2001 TD5 and have fingers crossed the grey/white ECU wire is behind the dash. Car does have ABS... well, at least an ABS light comes on when I start 2001 90 TD5 SW - Juice Motors Resto Mod - Epsom Green
2024 90 D300 HSE X-Dyn HT - Santorini Black |
22nd Feb 2024 3:23pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 677 |
I ran a wire from the ECU when I fitted my rev counter...at the time I was unaware that there might already be a wire in the instrument binnacle...where should I be looking next time I'm in there poking around?
22nd Feb 2024 4:06pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6489 |
In the plug (bulkhead side), pin 14 is the rev counter signal, usually WHITE/GREY.
It's one of the corner wires, if you have corner wires of WHITE/GREEN, GREY/BLACK, GREEN/BLUE and an empty corner then you're out of luck. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
22nd Feb 2024 4:11pm |
Excellent info... thanks Martin
22nd Feb 2024 4:21pm |
But if I have a blank corner on mine I can run the ECU wire to that connector and then just plug and play from the binnacle loom? |
23rd Feb 2024 10:44pm |
Does anyone know the pin types for the dash loom connector?
29th Mar 2024 6:46pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 488 |
The Grey 14-way connectors are Sumitomo HD090 Series Connectors.
Male connector on the instrument harness, female connector on the vehicle harness. I have both male and female terminals. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 5th Apr 2024 6:41pm. Edited 1 time in total |
29th Mar 2024 7:20pm |
Brilliant thanks for letting me know typically I only need one 😂 I'll have a search unless you have some spare I can buy off you?
29th Mar 2024 7:26pm |
I have plenty - I sell them (in 10's) on eBay
I'm happy to sell you just one, they're £0.30 each - but the stinger is the postage 'Large Letter' has just gone up to £2.10 for 1st Class. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
29th Mar 2024 8:11pm |
