Home > Technical > Momentary Hiccup |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
I would be inclined to take back to dealer Dara
Hope it's not that snorkel we fitted if it is it will be down to the holes you drilled |
17th Jun 2013 3:25pm |
LittleFoot Member Since: 25 Aug 2012 Location: east sussex Posts: 233 |
Those holes were perfect! Nah, noticed it 2 times in the weeks before we fitted the RAI.... Will ask dealer to plug it in when I get back from sunny Aberdeen next week. |
17th Jun 2013 3:50pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16946 |
My 2.4 was doing something like this, most noticeable when changing up. Ease off the power to change gear, reapply power and there'd be a noticable hiccup. Unfortunately no faults were being logged at all.
Latest remap from Pete at BAS made the problem go away, and replaced my frown with a big grin! |
17th Jun 2013 4:05pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3334 |
hi littlefoot,
my 2.2 is the same, only done 1k miles. Everynow and again, it will just miss a beat for a fraction of asecn |
17th Jun 2013 4:11pm |
dunno what happened there?
anyway, I get the same thing on the 2.2 and it's only done 1000 miles. Be cruising along and all of a sudden, the power will disappear for a fraction of a second and then it's back again. I'm coming to the opinion that they haven't quite got the ECU sorted very well. I also find it a pain in the a**e to drive at slow speeds as it sounds like it's gonna spit the gearbox out if you're crawling along in traffic and constantly changing between 1st and 2nd and back again . My TD5 is much better from that perspective.... |
17th Jun 2013 4:17pm |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Has it had the very latest software upgrade from LR?
17th Jun 2013 4:31pm |
Mine's only a couple of weeks old so would hope so....
17th Jun 2013 4:40pm |
Take nothing for granted, mine is a 5 month old MY13 and has just had an update which sorted out a hesitation problem
17th Jun 2013 4:48pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
Mine has the same feature, 1200 miles on the clock and started a couple of weeks ago.
Maybe Q225 is an ecu upgrade with a fix, if we can ever find out what Q225 is Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
17th Jun 2013 6:15pm |
Cheers all,
Blackwolf - sounds exactly the same. Dealers point blank denied there were any software updates. It seems wierd it has only just started.... I suspect it may not show up when plugged in? |
17th Jun 2013 6:22pm |
sib Member Since: 18 May 2007 Location: Baaath Posts: 144 |
I picked up a 90 pick up today, 1 year old, 3500 miles and it hiccuped a few times on my journey home. Only around 2000 rpm when acceleratiing It has just had a service. Is it the fuel grade ? Any thoughts ? Sib
Bath UK 1952 80 inch 1973 88 inch 2018 Morgan plus 4 narrow body |
18th Jun 2013 8:46pm |
PM Mike in the LR customer relations section your chassis number, he can check if there are outstanding ECU upgrades for you
He checked mine today and it is at the latest version. Q225 applies to 2012 models so that may need applying ? If I can get a consistent set of circumstances when the problem occurs I will take it into the dealer so I can show them the problem, until then I will live with it. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
18th Jun 2013 9:02pm |
Interesting to hear that my '12 is not the only to1 to be affected.
Apparently my truck is not affected by the q225 update either... |
19th Jun 2013 6:00pm |
Mines in next week to be done.
19th Jun 2013 6:04pm |
