![]() | Home > Puma (Tdci) > Is there an EGT sensor on the TDCi engine? |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Simple enough question:
Is there an EGT sensor on the TDCi engine? And of course leads to the two next questions: If there is does it report back to the CANbus or an ECU pickup? If so can something like a ScanGaugeII be programmed to read it realtime via the diagnostic port? I'm sure Pete or someone else will have the answer to this. Though I suspect the answer is that there is no EGT sensor. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
What's an ETG sensor? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4760 ![]() ![]() |
Maybe it is an EGR sensor? 1982 88" 2.25 diesel
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
exhaust gas temperature sensor? Mike
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Googling a little bit:
Exhaust Gas Thermocouple Sensor. If is that. Looks like do not have (at least doesnt appear in the GTR (workshop manual and electric library) Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
zeerover Member Since: 11 Jan 2009 Location: Ghent Posts: 17 ![]() ![]() ![]() |
Only in combination with a carbonfilter , not in the Puma
