Home > Technical > Cruise Control cutting out after new gearbox
andycowman
United Kingdom 2006 Defender 110 Td5 XS CSW Tonga Green
I successfully installed cruise control to my 2006 TD5 last year and all has been well...until my gearbox was replaced recently. R380 and now with the v8 5th ratio.
I did wonder if that would break it but its odd, it engages and cruises for a while and then cuts out? Is that likely a different issue?!
Any ideas would be greatfully recieved! I am not sure if the 5th ratio would require a speedohealer thing.
Cheers!
Post #1063827 25th Mar 2025 11:21am
bankz5152
Youve changed the ratios so the cruise now cant engage, i bet you anything it will work in 4th.
Post #1063831 25th Mar 2025 11:56am
Harry.O
Exactly the same issue with my TD5 110 after fitting a recon gearbox with the V8 5th gear ratio. I fitted a speedo healer and it's been faultless since then. A bit more info here:
https://www.defender2.net/forum/topic46380-15.html 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #1063957 26th Mar 2025 2:16pm
andycowman
Thanks chaps - thats exactly it! Ordered from Ashcroft today - and also will be doing that cruise control button Smile
Post #1063959 26th Mar 2025 3:42pm
