![]() | Home > Technical > Cruise Control cutting out after new gearbox |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2206 ![]() ![]() ![]() |
Youve changed the ratios so the cruise now cant engage, i bet you anything it will work in 4th.
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 723 ![]() ![]() ![]() |
Exactly the same issue with my TD5 110 after fitting a recon gearbox with the V8 5th gear ratio. I fitted a speedo healer and it's been faultless since then. A bit more info here:
https://www.defender2.net/forum/topic46380-15.html 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
andycowman Member Since: 22 Jan 2025 Location: devon Posts: 12 ![]() ![]() ![]() |
Thanks chaps - thats exactly it! Ordered from Ashcroft today - and also will be doing that cruise control button ![]() |
