![]() | Home > Technical > Single piece half shafts identification |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2720 ![]() ![]() |
No. Pull the rubber cap off and you’ll see the splines at the drive member.
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 586 ![]() ![]() ![]() |
Thanks. New single piece items arrived from LOF. I should get them fitted this week.
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2158 ![]() ![]() ![]() |
Remember to allow enough space to pull out the ‘long’ side - not too close to the garage wall as has been done by someone …ahem…
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 723 ![]() ![]() ![]() |
I'd recommend giving the external surfaces of the LOF shafts a bit of paint before fitting, mine went orange on the exposed flange part pretty quickly
![]() 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 151 ![]() ![]() ![]() |
I don’t think they come painted, merely sponged with some black food colouring ![]() Was cleaning the mating surfaces of my lof shafts, and wiped across the exposed surface, removing all black coating without even trying. Gave them a proper clean and a coat of buzzweld Chassis in one ![]() |
Solid half shafts now installed. Very happy, driveline clunk gone and much smoother to drive. Well worth the upgrade and the LOF shafts were not that expensive.
Glad you’re sorted and happy
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2322 ![]() ![]() ![]() |
