![]() | Home > Technical > Single piece half shafts identification |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2719 ![]() ![]() |
No. Pull the rubber cap off and you’ll see the splines at the drive member.
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 585 ![]() ![]() ![]() |
Thanks. New single piece items arrived from LOF. I should get them fitted this week.
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2147 ![]() ![]() ![]() |
Remember to allow enough space to pull out the ‘long’ side - not too close to the garage wall as has been done by someone …ahem…
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 721 ![]() ![]() ![]() |
I'd recommend giving the external surfaces of the LOF shafts a bit of paint before fitting, mine went orange on the exposed flange part pretty quickly
![]() 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 151 ![]() ![]() ![]() |
I don’t think they come painted, merely sponged with some black food colouring ![]() Was cleaning the mating surfaces of my lof shafts, and wiped across the exposed surface, removing all black coating without even trying. Gave them a proper clean and a coat of buzzweld Chassis in one ![]() |
