![]() | Home > Technical > My 110 won't start |
Irish rover Member Since: 25 Feb 2025 Location: Leinster Posts: 9 ![]() ![]() |
1999 Defender 🙄, big fingers, small keypad😁
revd Member Since: 20 Apr 2024 Location: England Posts: 212 ![]() ![]() |
removing the alarm may have upset the inbuilt immobiliser
Yes I'm starting to think that? Everything else is working lights, wipees etc, starter and battery are strong, I just can't figure out why the fuel pump and the engine light are not working??? It's recking my head 🤪
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 225 ![]() ![]() ![]() |
With the temp gauge going into the red, it sounds like it might possibly be an earth problem. Have you reconnected the bulkhead earth wires where you must have disconnected them, ie in the engine bay etc, just a thought,
Ashby Andy 👍 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5839 ![]() ![]() |
The emergency fuel cut off button is connected and reset???
Thanks everyone, yet I've been checking the earth's I will get the wiring diagram and double check, these wiring diagrams are not easy to follow, unless your an auto electrician,which I am definitely not 🤔. Where is the emergency fuel cut off switch??
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 804 ![]() ![]() ![]() |
Fuel cut off is on the bulkhead just about and to the right of the clutch resivoir (viewed from the front)
Edit.... Between the coolant resivoir and air box Last edited by rustandoil on 18th Mar 2025 7:54pm. Edited 1 time in total |
I know it was fitted, but I will check the connections,but it's still a problem to check with the engine light issue, I will check the earth's tomorrow 🤞
