![]() | Home > General & Technical (L663) > Stockist for 110 Hardtop rear window motors install? |
BadgerWaz Member Since: 15 Jul 2024 Location: Somewhere else Posts: 110 ![]() ![]() |
So: the window motors are in situ which is a bonus. No harness, but everything else is there.
With power applied to the motor the glass goes up and down perfectly, so it's going to be straightforward wiring a two-way switch to each door. I spent far too long carefully picking at one of the plastic window covers but it's that brittle it still broke away in a few places. On the second plastic cover I just man-handled it off and snapped it in half with great satisfaction ![]() All I need to do now is call LR and ask for costs on the plastic trim kit, and wire the motors up the next weekend I have free. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
Beware it is NOT just the case of a wiring harness (or two). It may need a third harness in the drivers door.
Then you will need a modified Body Control Unit and an update software (could be part of GAP IID) tool. I did something similar on a Disco series 2 Commercial many years ago, well before 'ECU electrics, it was all relays as I remember. ![]() |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3028 ![]() ![]() |
You could maybe get any extra parts from a breakers. The new Defender is starting to appear in salvage dealers.
I won't need to update software on such a simple circuit as it's going to be independant and not part of the vehicle harness.
I'll be running a power supply via a relay, and using a reverse polarity switch. I'll fit two independant rocker switches in the centre console. I don't need to replace the drivers door switch panel as I won't be using the existing windows circuit. Easy peasy. |
You didn't say in your OP you were going to 'bodge' the wiring !!
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1850 ![]() ![]() ![]() |
You shouldn't refer to that as a bodge, old school would be more appropriate!
