Home > Puma (Tdci) > Strange rattle / graunching noise
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi all
2007 Defender Puma 90 which is well maintained. When driving every now and then there is a strange rattle / graunching noise from the rear offside wheel area. I have checked around the wheel and wheel arch and everything looks in order and correctly attached. There is a couple of mm play in the half shaft and drive flange. Would this make the noise I have described?
Jim
Post #1062112 5th Mar 2025 9:12pm
Mo Murphy
Put it in diff lock with handbrake on. Jack up the offending corner and holding the wheel at 9 o'clock and 3 o'clock try to rock it from side to side to feel for play in the wheel bearings.
Chock the other 3 wheels securely, take the handbrake off and spin that wheel by hand. It should spin freely without any roughness or resistance.
Graunching sounds usually indicates a wheel bearing breaking up inside the hub.
Let's hope it's not that.
HTH
50 Shades of Pennine Grey
Post #1062127 5th Mar 2025 10:45pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Couple mm? Pull the drive flange and look at the splines on the flange and axle. One of mine was worn down to almost nothing. I changed both axles and all my drive flanges. Much quieter now.
Post #1062138 6th Mar 2025 12:30am
jim4244
Update - I don’t think that the noise is coming from the rear O/S wheel now. It sounds more towards the centreline of the vehicle. I’m starting to think that it could be the shoes or gubbings in the handbrake?
Anyone else had any strange vibrations or noise from their handbrakes?
Jim
Post #1062353 8th Mar 2025 9:44am
revd
deleted
Post #1062364 8th Mar 2025 1:29pm
jim4244
Drama over! I had my neighbour drive the Landy while I laid in the back with my ear to the floor. Found that it was the exhaust pipe occasionally touching the removable crossmember just under the gearbox. A quick adjustment has now cured what I was dreading was going to be an expensive job Thumbs Up
Jim
Post #1062391 8th Mar 2025 6:39pm
ickle
Thats a happy ending.
Post #1062403 8th Mar 2025 8:01pm
jst
I'd still check those rear shafts/drive members omif 2mm play. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1062406 8th Mar 2025 8:36pm
jbcollier
+2 on that.
Post #1062449 9th Mar 2025 2:46pm
jim4244
I did recheck the rear half shafts and drive flanges. I was a little out on my 2mm estimation Rolling with laughter
There is some slight movement which I’m not overly concerned about. I did grease up the end of the half shafts as they were bone dry…
Jim
Post #1062450 9th Mar 2025 2:50pm
