![]() | Home > Maintenance & Modifications > Defender A Post Leak |
alfajock Member Since: 12 Jan 2011 Location: Bedfordshire Posts: 227 ![]() ![]() ![]() |
Not very. It's supposed to cure in water, it's more sensitive to cold I believe. I did my leaks outside in October and it seems to have done the trick Fully Restored 89 110 CSW V8
CLS 350 CDI for the sensible stuff |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
I rebuilt a series 3 a few years back and I used Tigerseal to seal all my joints. Its a sealant/adhesive that is very robust, resists UV attack and comes in black, white and grey. You need a caulking gun to apply it. Highly recommended.
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Brilliant bit of info
![]() So I know what to do in the summer ![]() Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 ![]() ![]() |
Yeh, I have sealed all of the windows on the 90 now.
So definitely no water coming in there. However still have the leak ![]() Think it's coming from the joint between the roof and the vertical panels if that makes sense. Not sure how best to stop it coming in from there so going to have to have a think Will Defender 90 XS TD5 (03 Reg) |
