Home > Puma (Tdci) > TDCI 2.4 Alarm system + central locking
WPRO18
 2005 Defender 90 Td5 SW Cairns Blue
I've got a late base model 2.4 TDCI which is simple key locking. Does it have a factory immobiliser?
Pending some modifications soon to be taken, my insurance are asking for a CAT 1 system to be installed so wondered if others could please suggest of a good system? Ideal if you could suggest one that's works well with a soft top?
Also, am I right in thinking I can have retrofitted central locking (currently don't have at all) whilst the alarm is being fitted (if so what do I need to buy)?
Thank you!
Post #1061877 3rd Mar 2025 7:11pm
Ianh
If you have a fob that needs to be on your key ring with a good battery in it to start the vehicle then you will have a 10AS alarm unit with an immobiliser funcion enabled. If you don’t have a fob then you won’t have an immobiliser enabled and your engine ECU will not be expecting a de-immobilisation code to be received before it will allow the engine to start.
You can retrofit central locking, there are a fair number of topics on it. If you are getting a third party cat 1 system fitted it will control the actuators and you can get gen ones or after market ones.
It’s interesting to note that even the last highest specification defenders that rolled off the production line with immobiliser, central locking, internal movement sensors and a battery backup sounder were only certified as Cat 2.
Post #1061880 3rd Mar 2025 7:41pm
WPRO18
Thank you for the guidance back.
Mine has no remote so imagine it has no immobiliser. Also thanks re: central locking I've since found some actuators so will query this with the potential alarm fitter.
In this respect sounds quite straightforward alarm install therefore
Post #1061950 4th Mar 2025 9:28am
Ianh
If you take the drivers footwell speaker out ( just a few screws) then with your head in the footwell you look up and to the right through the aperture. You can see if a 10AS alam unit is fitted. It’s a 6 inch x 4 inch green plastic box attached to the bulkhead with two loom connectors going to it.
Post #1061964 4th Mar 2025 12:18pm
WPRO18
Thanks for this guidance.
Had a look this weekend, there is a 10AS green box. My car key (with the Land Rover logo) on it looks fairly basic, so does that mean a transponder / immobiliser or something is inside of it?
Is it possible my 10AS system is disabled? If so, will this complicate the fitting of a CAT1 install retrofit?
UPDATE: If somebody searches and reads this...
- Original alarm in place and would immobilise vehicle if 10AS box disconnected. Despite no fobs the system still operates.
- CAT 1 fitted in straightforward manner.
Post #1062469 9th Mar 2025 6:55pm
